Insert figure in the Prime.
10-06-2014, 11:59 AM
How do I insert pictures in Hp Prime in order to interact with the program?
For example:
https://www.youtube.com/watch?v=Se_5QlkU...KByYAyvyHg
Thanks
10-06-2014, 02:15 PM
RE: Insert figure in the Prime.
I did a tutorial on something very much related to what you are asking. Basically, you have to create the image, and convert into a certain format with a separate program called DIMGROBHELPER. The video walks you through the entire process.
http://www.hpmuseum.org/forum/thread-315.html
Graph 3D | QPI | SolveSys
10-06-2014, 02:30 PM
Thanks!!!
10-06-2014, 03:20 PM
By the way, if your image is simple and can be generated by means of simple shapes, it may be better to generate it (rather than importing into an ICON) by using FILLPOLY, TRIANGLE, RECT, and similar commands.
10-06-2014, 04:46 PM
could you put a code like example?
