saturnng, resurecting another HP 48 & 49g emulator for Linux
10-07-2024, 07:56 AM
Hello, after x48ng (which is still maintained actively) I forked another old emulator: saturn, by Ivan Cibrario Bertolotti.
Here is the source of my fork: https://github.com/gwenhael-le-moine/saturnng Here's some screenshots (from the source repository): I started after finishing the new SDL2 GUI for x48ng. I finally had a good enough frontend to plug onto the core emulator. It went well and I had it running quickly. The real breakthrough was when I tried again to run the hp49 mode with ROM 2.15 and it worked! The original X11 UI showed a popup for every warning which made it unusable but my GUI doesn't interrupt the user, the warning is only printed on stderr. I also added the possibility to run a 48SX ROM. There's still bugs in the emulation that need fixing but at least for my basic usage it's usable. I can play MINEHUNT there too. "My" emulators: x50ng & more |
10-08-2024, 04:08 PM
RE: saturnng, resurecting another HP 48 & 49g emulator for Linux
Thank you!
It ain't OVER 'till it's 2 PICK |
