mixed fraction program for hp 28s
10-10-2024, 07:46 PM
i found this program some time ago that gives a mixed fraction on hp 28s. After keying in the program it returned a syntax error. does anyone know what might be wrong with it, or better, have a working program to share? here's the malfunctioning one i've tried:
"The following is the one that gives output like '3+4/5' for 3.8
<< -> a
<< a IP ->NUM ->STR
IF a ->NUM FP
THEN "+" + a FP FRAC O->S +
END S->N
cheers!
10-10-2024, 08:15 PM
RE: mixed fraction program for hp 28s
I don't believe FRAC, O->S or S->N are valid commands.
10-11-2024, 08:44 AM
Something like this?
DIR
  R\->N
    \<< \->NUM \-> a
      \<< a IP \->STR
        IF a FP
        THEN "+" + a FP FRAC O\->S +
        END S\->N
  FRAC
    \<< \-> a
      \<< (0,1) (1,1)
        WHILE DUP2 + DUP C\->R / DUP a \=/
        REPEAT
          IF a <
          THEN SWAP ROT
          ELSE SWAP
          END DROP
        END DROP ROT DROP SWAP DROP C\->R
  O\->S
    \<< "/" SWAP + +
  S\->N
    \<< "'" SWAP OVER + + STR\->
END
Examples
3.8
R→N
'3+4/5'
'π^2/6'
R→N
'1+727069/1127354'
Warning: Don't try negative numbers.
10-11-2024, 09:10 AM
Addendum: Just remembered this older thread: fraction program hp 28s?
It contains also a program FRAC but I haven't checked if this would work here.
10-11-2024, 02:47 PM
(10-10-2024 08:15 PM)Steve Simpkin Wrote:  I don't believe FRAC, O->S or S->N are valid commands.
i tried it without, the syntax error was gone but the program is still not working, when prompted it displays the entire program..
10-11-2024, 02:51 PM
(10-11-2024 08:44 AM)Thomas Klemm Wrote:  Something like this?
DIR
  R\->N
    \<< \->NUM \-> a
      \<< a IP \->STR
        IF a FP
        END S\->N
  FRAC
    \<< \-> a
      \<< (0,1) (1,1)
        REPEAT
          IF a <
          THEN SWAP ROT
          ELSE SWAP
          END DROP
  O\->S
    \<< "/" SWAP + +
  S\->N
END
Examples
3.8
R→N
'3+4/5'
'π^2/6'
R→N
'1+727069/1127354'
i was getting syntax error and the cursor is placed at the parenthesis (1,1) i changed the commas in both parentheses to a point but then it returns a syntax error with cursor placed at the very end of the program..
is it working on your calculator?
10-11-2024, 04:13 PM (This post was last modified: 10-11-2024 07:02 PM by Thomas Klemm.)
(10-11-2024 02:51 PM)Rafa Wrote:  I was getting syntax error and the cursor is placed at the parenthesis (1,1)
You probably use a comma , instead of a period . as decimal point character.
Either use a semicolon ; or just a space between the numbers: (0 1) (1 1)
(10-11-2024 02:51 PM)Rafa Wrote:  is it working on your calculator?
It runs on an HP-48. I assumed it would run on an HP-28 too.
If complex numbers don't work, you could try using vectors instead: [0 1] [1 1]
And then use V→ instead of C→R to decompose them.
10-11-2024, 06:35 PM (This post was last modified: 10-11-2024 07:06 PM by Gilles.)
With my HP50g it could be :
R→N : « DUP IP OVER FP →Q + »
But perhaps →Q dont exists on the 28S ?
Why use string objects while algebraic objects does the job ?
10-11-2024, 06:59 PM
(10-11-2024 06:35 PM)Gilles Wrote:  With my HP50g it could be :
R→N « DUP IP OVER FP →Q + »
Correct, →Q was not introduced until the HP-48SX.
10-11-2024, 07:15 PM (This post was last modified: 10-11-2024 07:18 PM by Thomas Klemm.)
Interestingly your program gives a different answer:
'π^2/6'
→NUM
R→N
'1+78609550141/121887731137'
Both results evaluate to the same initial value:
1.64493406685
Thus I wonder which algorithm is used in →Q.
10-11-2024, 07:33 PM (This post was last modified: 10-11-2024 07:35 PM by Gilles.)
(10-11-2024 06:59 PM)Steve Simpkin Wrote:  Correct, →Q was not introduced until the HP-48SX.
So we could perhaps create this one with the FRAC below, the algebraic 'A/B' and the OBSUB command I see in the 28s reference manuel. Just an idea, i dont own a 28S and OBSUB dont exist in the 48SX and 50g si In can't test.
10-11-2024, 07:58 PM (This post was last modified: 10-11-2024 08:13 PM by Gilles.)
(10-11-2024 07:15 PM)Thomas Klemm Wrote:  Thus I wonder which algorithm is used in →Q.
I don't know the algorithm but the accuracy of →Q depends on the FIX parameter.
I was always impressed by its speed, even with my old 48SX. There is also a command →Qπ which allows to retrieve for example π/4 with the real value of ACOS (√2/2) in radians. And √2/2 →NUM →Qπ returns √(1/2) , then simplify returns √2/2
AUR says :
Quote:To Quotient Command: Returns a rational form of the argument.
The rational result is a “best guess”, since there might be more than one rational expression
consistent with the argument. →Q finds a quotient of integers that agrees with the argument to
within the number of decimal places specified by the display format mode.
→Q also acts on numbers that are part of algebraic expressions or equations
And for →Qπ
Quote:To Quotient Times π Command: Returns a rational form of the argument, or a rational form of
the argument with π, square roots, natural logs, and exponentials factored out, whichever yields
the smaller denominator.
consistent with the argument. →Qπ finds a quotient of integers that agrees with the argument to
→Qπ also acts on numbers that are part of algebraic expressions or equations.
10-11-2024, 08:10 PM
(10-11-2024 06:35 PM)Gilles Wrote:  Why use string objects while algebraic objects does the job ?
The problem is that numbers can't be quoted.
This is the best I could come up with:
4 5
O→S
"4/5"
S→N
'4/5'
But I agree, from this point on the integer part could just be added.
Apart from a minor change I didn't bother to rewrite the main function but just added the missing ones to make it work.
10-11-2024, 08:17 PM
4 5
O→S
"4/5"
S→N
'4/5'
What about :
'A' 1 {123} OBSUB
does it returns '123' ?
or perhaps
'A' 1 123 OBSUB
10-12-2024, 11:45 AM (This post was last modified: 10-12-2024 11:46 AM by John Keith.)
\->Q PROPFRAC is even shorter.
10-13-2024, 06:56 PM
Big Grin One life is not enough to master all the subtleties of the 50g !
