Ranks calculation
10-31-2024, 01:39 PM
Ranks calculation
Hello everyone, some statistical tests, especially non-parametric ones, require the calculation of ranks. Is there a way to calculate them with HP PRIME?
For example, given a column vector:
[[1],[3],[5],[1],[4],[5],[6],[1]]
the ranks are:
[[2],[4],[6.5],[2],[5],[6.5],[8],[2]].
Thanks for your help, Roberto
10-31-2024, 02:38 PM
RE: Ranks calculation
(10-31-2024 01:39 PM)robmio Wrote:  For example, given a column vector:
the ranks are:
Is rank of matrix supposed to be a single number?
What does above list of numbers mean?
10-31-2024, 02:46 PM
the ranks are:
It is not the rank of a matrix, but the scores to be given to the various values. For example, ranks are used in the statistical test "Wilcoxon signed-rank test": https://www.technologynetworks.com/infor...est-370384
10-31-2024, 02:50 PM
See also: https://real-statistics.com/non-parametr...anks-test/
10-31-2024, 04:41 PM
def ranking(m):
    hi = len(m)
    m2 = zip(m, range(hi))
    m2.sort()        # sort with index
    lo, m3 = 0, m[:] # work with a copy
    for i in range(hi):
        j = i+1
        if j != hi and m2[i][0]==m2[j][0]: continue
        r = (lo+i)/2 # j-lo items have same ranking
        for k in range(lo,j): m3[m2[k][1]] = r+1
        lo = j
    return m3
p2> ranking([1,3,5,1,4,5,6,1])
[2.0, 4.0, 6.5, 2.0, 5.0, 6.5, 8.0, 2.0]
10-31-2024, 08:16 PM
(10-31-2024 04:41 PM)Albert Chan Wrote:
def ranking(m):
    hi = len(m)
    for i in range(hi):
        j = i+1
        lo = j
    return m3
Thank you so much, Albert Chan. I really appreciate it! Kind regards, Roberto
10-31-2024, 08:42 PM (This post was last modified: 10-31-2024 09:18 PM by Albert Chan.)
Note that Python has 0-based array.
If code were for Python use, I would assign r back to the ranking list, instead of r+1
Lua array is 1-based, and probably easier to port to HP Prime
function ranking(m)
    local m2, m3, lo, hi = {}, {}, 1, #m
    for i=1, hi do m2[i] = {m[i],i} end
    table.sort(m2, function(x,y) return x[1]<y[1] end)
    for i=1, hi do
        local j = i+1
        if i<hi and m2[i][1]==m2[j][1] then continue end
        local r = (lo+i)/2
        for k=lo, i do m3[m2[k][2]] = r end
        lo = j
    end
    return m3
end
lua> pprint( ranking{1,3,5,1,4,5,6,1} )
{ 2, 4, 6.5, 2, 5, 6.5, 8, 2 }
11-01-2024, 07:41 AM
(10-31-2024 08:42 PM)Albert Chan Wrote:  Note that Python has 0-based array.
function ranking(m)
    for i=1, hi do
        local j = i+1
        local r = (lo+i)/2
        lo = j
    end
    return m3
end
Thank you very much, Albert Chan. I have translated your Python program into a Cas program:
#cas
ranking(m):=
LOCAL hi, m2, m3, lo, j, ii, r, k;
hi:= length(m);
m2:=zip(m, range(hi).+1);
m2:=sort(m2);
lo:=1;
m3:=m;
FOR ii FROM 1 TO hi DO
j:=ii+1;
IF j≠hi AND m2[ii][1]==m2[j][1] THEN
CONTINUE;
r:=(lo+ii)/2;
FOR k FROM lo TO ii DO
m3[m2[k][2]]:=r;
lo:=j;
RETURN m3;
#end
11-01-2024, 09:04 AM
Unfortunately, there is an error in the following program, and I can't figure out what it is:
#cas
ranking(m):=
hi:= length(m);
m2:=sort(m2);
lo:=1;
m3:=m;
j:=ii+1;
CONTINUE;
r:=(lo+ii)/2;
m3[m2[k][2]]:=r;
lo:=j;
RETURN m3;
#end
For example:
ranking([7,5,7]) --> [2,1,3]
instead of:
ranking([7,5,7]) --> [2.5,1,2.5]
11-01-2024, 09:38 AM (This post was last modified: 11-01-2024 10:13 AM by Albert Chan.)
(11-01-2024 09:04 AM)robmio Wrote:  Unfortunately, there is an error in the following program, and I can't figure out what it is:
Off-by-1 error (Lua code use i<hi, with same effect)
i≠hi guard is to *ALWAYS* update last ranking. (*)
< IF j≠hi AND m2[ii][1]==m2[j][1] THEN
> IF ii≠hi AND m2[ii][1]==m2[j][1] THEN
(*) It is weird bad code does not generate Index outside range error, when j = hi+1
Update: fixed typo, should be ii instead of i
11-01-2024, 10:03 AM
> IF i≠hi AND m2[ii][1]==m2[j][1] THEN
Hi Albert Chan, your fix works fine. Also, if we replace "i" with "j" in the following line:
"FOR k FROM lo TO ii DO"
the code generates Index outside range error.
Thanks again, many thanks!
11-01-2024, 10:04 AM
This version works fine.
#cas
ranking(m):=
hi:= length(m);
m2:=sort(m2);
lo:=1;
m3:=m;
j:=ii+1;
CONTINUE;
r:=(lo+ii)/2;
m3[m2[k][2]]:=r;
lo:=j;
RETURN m3;
#end
11-01-2024, 10:34 AM (This post was last modified: 11-01-2024 11:14 AM by Albert Chan.)
(11-01-2024 10:03 AM)robmio Wrote:  the code generates Index outside range error.
I mean when we do equality test, Index outside range not producing error
Cas> m := [1,2,3]
Cas> m[3] == m[4]      → 0
Cas> m[4] == m[5]      → 0
Cas> m[5] == m[6]      → 0
m2[hi][1]==m2[hi+1][1] guard should also generate 0, i.e. always update last ranking.
If we use this undefined behavior (not recommended), we can drop ii≠hi guard.
Interestingly, I discovered this due to a typo , i≠hi instead of ii≠hi
Since i = √(-1) is imaginary, i≠hi is always true, same as no guard.
User(s) browsing this thread: 6 Guest(s)
