DM32 Firmware
11-09-2024, 02:04 PM (This post was last modified: 11-10-2024 12:16 PM by n1msr.)
DM32 Firmware
I looked on Swiss Micros' page and found a QSPI file for the DM32 in the DM32 Firmware - QSPI - part directory, but the file is called DM42_qspi_3.x.bin.
Why is this file, which looks like it is for the DM42, in the DM32 firmware directory? Does the DM32 use this?
Thank you.
11-11-2024, 06:37 AM (This post was last modified: 11-11-2024 05:21 PM by RPNerd.)
RE: DM32 Firmware
(11-09-2024 02:04 PM)n1msr Wrote:  Why is this file, which looks like it is for the DM42, in the DM32 firmware directory? Does the DM32 use this?
If memory serves, the data in this file is a bunch of constants used by the Intel decimal floating point library, and there are a LOT of them.
The DM32 uses the same library, so it stands to reason that it needs those constants in the same way that Free42 running on the DM42 needs them.
Current daily drivers: HP-41CL, HP-15C, HP-16C
