Input line expression editor failure
11-11-2024, 02:14 AM
(This post was last modified: 11-11-2024 12:45 PM by compsystems.)
Hello
In the power operation, if the base is in brackets () and if you write a fraction and then place it in the history and then copy it to the input line, it no longer allows you to add operations to the fraction. (-1/2)^2 [enter] [copy] (|-1/2)^2 // The cursor | does not allow positioning before or after the fraction. (-1/2|)^2 |
11-13-2024, 10:15 PM
RE: Input line expression editor failure
You have Entry set to "Textbook" in home settings, right?
Use the up and down buttons to move the cursor between the top and bottom parts of a fraction. |
