Evaluation in an expression of Degrees Minutes Seconds
11-14-2024, 12:37 AM
(This post was last modified: 11-14-2024 05:41 PM by compsystems.)
The evaluation in an expression of Degrees Minutes Seconds is not performed.
(a°b′c″|[a = 74,b = 42,c = 15]) [Enter] a°b′c″ => 74°42′15″ subst(aº,a = 74) [Enter] Syntax Error In addition, you have to keep the expression and only with approx() convert it to a decimal number. 74°42′15″ [Enter] 74°42′15″ approx(74°42′15″) [Enter] 74.7041666667 |
11-14-2024, 02:27 PM
(This post was last modified: 11-14-2024 02:29 PM by rawi.)
RE: Evaluation in an expression of Degrees Minutes Seconds
Deleted
11-14-2024, 06:41 PM
There is the hms comands to convert to and from hms
->hms. To hms And hms-> from hms |
