possible BUG when simplifying expressions with units
11-14-2024, 05:32 PM
Hello
There is a possible BUG when simplifying expressions with units
74_deg + 42_mn*(1_deg/60_mn) + 15_s *(1_deg/3600_s); [Enter] 74.7041666667_deg
but
60_min/1_deg = 1_deg/1_deg [Enter] (60_(mn*deg^-1)) = (1_(deg*deg^-1))
expected 60_mn/1_°= 1
https://www.wolframalpha.com/input?i=60+...eg%2F1+deg
11-18-2024, 03:12 PM
RE: possible BUG when simplifying expressions with units
a similar case
(60_mn = 1_deg)/(1_deg) [Enter] (60_(mn*deg^-1)) = (1_(deg*deg^-1))
simplify(60_(mn*deg^-1) =1_(deg*deg^-1)) [Enter] (60_(mn/deg)) = (1_1)
11-18-2024, 05:05 PM
_mn is a time unit.
_deg is not a real unit (angle unit do not have a physical dimension), it's just 2*pi/360.
You can check that with mksa(...)
12-21-2024, 03:49 PM
In HOME the units for angular dimensions are:
  • Degree: _deg
  • Minute: _arcmin
  • Second: _arcs
USIMPLIFY(60_arcmin/1_deg) gives the correct answer: 1
Josep Mollera. HP PRIME, HW: C, SW: 2.2.15157 (2024-09-01).
