(25) MASTER MIND
11-15-2024, 09:15 AM
(25) MASTER MIND
This program was extracted from DISPLAY-V4N5&6 p.12:
D.KREJTSCHA (537) Wrote:Ein grundsätzliches Problem für den HP-25 Besitzer ist immer wieder die auf 49 Schritte beschränkte Programmkapazität. This listing works with this HP-25 emulator: Code: 01: 15 41 : g x<0 Example f CLEAR PRGM f FIX 0 10 STO 1 -4711 R/S 0. 1234 R/S 2. 5126 R/S 1. 7813 R/S 11. 3919 R/S 10. 4711 R/S 4711. D.KREJTSCHA (537) Wrote:A fundamental problem for the HP-25 owner is always the limited program capacity of 49 steps. |
11-15-2024, 09:51 AM
RE: (25) MASTER MIND
You may compare it to the MASTERMIND DELUXE program that is listed in the HP-25 Library Programs-PPC Jrnl.pdf (PPC JOURNAL V5 N10 PAGE 20) of this zip-file.
The listing can be found in the file ppc/HP25_MasterMind.25 attached to this post: Code: 01: 23 01 : STO 1 |
