GetFromHome
11-15-2024, 01:48 PM
GetFromHome
It’ common knowledge that RPN uses uppercase letters for variables, and CAS uses lowercase. You can define expressions in RPN, using apostrophes in the first expressions. Like: ‘(A+B)’ Then You can build expression in classic RPN, for example: 3 X/y – gives: (A+B)^3 etc. If You wish, and You are RPN Orthodox But for more advanced expression transformations, You should transfer it to CAS. Nothing simpler, just press: Menu→Get from Home. But, there is a primitive failure. Transfer from Home to CAS, doesn’t change uppercase to lowercase. It’s a shame… Maybe I’m blind, but I didn’t found any method to automatically changed case. Strange, that there are no parameters, that define behavior GetFromHome. So I wrote simple program: Home2Cas: You Can put its template to User Keys, for example: KEY K_Home() BEGIN RETURN "Home2Cas({""X"",""Y"",""Z"",""A"",""B"",""C""},{x,y,z,a,b,c},"""")"; END; In the last quotation mark, You should insert Home expression (Menu→Get from home). And voila By the way: Some my question: Is it possible to open menu „Menu->GetFromHome” from PPL? This would simplify discussed operation. And here is the code: EXPORT Home2Cas(Zs,Zd,str1) BEGIN LOCAL L,SS,DD,I; L:=SIZE(Zs); IF L==0 THEN str1:=REPLACE(str1,Zs,STRING(Zd)); RETURN CAS.expr(""+CAS(str1)+""); END; FOR I FROM 1 TO L DO SS:=GET(Zs,I); DD:=GET(Zd,I); str1:=REPLACE(str1,SS,STRING(DD)); END; RETURN CAS.expr(""+CAS(str1)+""); END; Regards |
