HP PRIME UPDATE
11-19-2024, 02:06 AM
(This post was last modified: 11-19-2024 02:08 AM by RIBEIRO.)
HP PRIME UPDATE
an example of the program the code is this one that reports a syntax error the name of the program is
test():= BEGIN RETURN; AND; when I put it like this #cas test():= BEGIN RETURN; AND; #and then in this code structure it gives the syntax error, this only happens when I put # in line 1, when I put it in cas mode this is happening after the 2.2 update. Could you help me please? Send this user an email Send this user a private message Find all posts by this user |
11-19-2024, 02:39 AM
RE: HP PRIME UPDATE
Here is a link to a ppl program I posted three years ago. I think it is simple enough
to get an idea of program syntax. It is not a spectacular program. Good luck. https://www.hpmuseum.org/forum/thread-17...hlight=ppl Regards |
11-19-2024, 06:27 AM
RE: HP PRIME UPDATE
Current daily drivers: HP-41CL, HP-15C, HP-16C |
