Sharp PC-1500A Compiler
11-21-2024, 06:05 AM
Has anyone tried this program? Unfortunately, it doesn't work for me, and after running RUN, some initialization takes place without error, but the program exits and DEF commands don't work.
http://www.pc1500.com/abc-compiler.html |
11-21-2024, 03:34 PM
RE: Sharp PC-1500A Compiler
No, have not used that one. I use the TASM extension I wrote for VS Code:
https://github.com/Jeff-Birt/TASM_vsCode_Extension Also helpful is the PC-1500 library builder: https://github.com/Jeff-Birt/Sharp_PC-1500_Lib_Builder |
Yesterday, 05:49 AM
Thank you for the info. The program as such works, in fact all commands work, only the IF...GO command doesn't work, strange. But GO itself works.
