RPL That Stack
11-23-2024, 05:07 PM (This post was last modified: 11-23-2024 08:28 PM by raprism.)
RPL That Stack
You may listening to Rattle That Lock and ...
  • learning RPL
  • want to showcase RPL code
which is eventually 'Not quite HP', but tributable like e.g. for db48x.
11-23-2024, 05:22 PM (This post was last modified: 11-29-2024 08:42 PM by raprism.)
RE: RPL That Stack - MVTO, CPTO, CD
These are db48x examples for some 'file-like management stuff' to move or copy objects to subdirs or paths (and related chdir command).
    @ Usage: 'obj1' { HOME sub1 subsub2 } MVTO
    Duplicate2 CPTO Swap
    Purge Drop
'MVTO' STO
    @ Usage: 'obj1' { HOME sub1 subsub2 } CPTO
    DirectoryPath
    → new old
        Duplicate new CD Recall
        Swap Store old CD
'CPTO' STO
    @ Usage: 'obj1' 'obj2' MV
    2 Pick Recall Swap Store
    Purge
'MV' STO
    @ Usage: { HOME sub1 subsub2 } CD
    @ Usage: { subdirhere } CD
                →Prg Evaluate
'CD' STO
Note that at first I was trying to make use of local variables all the times, but contrary to some HP48 examples it turned out on db48x that with my beginner level evaluation of variables 'kicked in' too often.
So time to train also some stack commands.
For sure some conditional tests could be added. But for now I was happy to get something working as intended.
I'm sure RPL experts will have some ideas for improvements. Looking forward to it.
EDITs:
  1. CD uses now MAP
  2. CD uses now →Prg
11-29-2024, 07:51 PM
RE: RPL That Stack
(11-23-2024 05:22 PM)raprism Wrote:  These are db48x examples for some 'file-like management stuff' to move or copy objects to subdirs or paths (and related chdir command).
    Purge Drop
'MVTO' STO
    DirectoryPath
    → new old
        Swap Store old CD
'CPTO' STO
    Purge
'MV' STO
                Duplicate Evaluate
        Map Drop
'CD' STO
Local variables are evaluated on DB48x unlike RPL. This is notably because I like putting subprograms in a local variable and executing it like a regular program. This is one of the deviations from HP RPL that is both intentional and has no flag controlling it. I could certainly add such a compatibility flag. If you don't want evaluation, you can always quote the variables.
EDITs:
  • CD uses now MAP
I think an alternative to your CD would be:
    →Prg Evaluate
DB48X,HP,me
11-29-2024, 08:39 PM
RE: RPL That Stack
(11-29-2024 07:51 PM)c3d Wrote:
(11-23-2024 05:22 PM)raprism Wrote:  [...]
No urgent need for compatibility flag - will try to make use of quotations.
(11-29-2024 07:51 PM)c3d Wrote:  [...]
    →Prg Evaluate
Thanks for your hints. This alternative looks ideal.
