Where is the integration constant?
11-27-2024, 06:18 AM
Why integration of x gives 0.5x^2 without the integration constant? Whereas other CAS apps such as Geogebra, which I think it has the same CAS engine as Prime, adds an integration constant.
11-27-2024, 10:35 AM
RE: Where is the integration constant?
I think it is left out because since you can choose it whatever you like it is useless. As well other CAS calculators (TI inspire CX II-T CAS and Casio CP 400) do not use it.
11-29-2024, 04:44 PM
You can force an integration constant with a 3rd arg, e.g.
integrate(x,x,c) |
11-29-2024, 07:30 PM
RE: Where is the integration constant? | |||
