[DB50X on DM32] library programs? (*.48s)
Yesterday, 01:28 PM
(This post was last modified: Yesterday 01:30 PM by n1msr.)
I have not succeeded in adding a program to the library of the DB50X running on a Swiss Micros DM32. I am running the latest (v0.8.6) version of DB50X.
I could not find a demo or explicit instructions so I simply added to what is included in the release of v0.8.6 of DB50X in the Github repository. The [RPL] program is named RCH.48s (it's the HHC 2011 programming contest winner). See the listing below. When I did as described below (steps 1 and 2), I see the RCH program in the library menu under "Performance", but if I try to run it, I get this error: XlibName error: Invalid or unknown library entry 1. I edited the config/library.csv file in the "Performance" [menu] section like this: "Performance" "NQueens", "=" "SumTestWithFunction", "=" "SumTestWithLoop", "=" "Recursion", "=" "UnitsBenchmark", "=" "RCH", "=" 2. I copied RCH.48s from my PC via the USB cable to library/RCH.48s on the DM32 (where the library programs are that come with the release). Note: the program requires a string of any length, e.g. "AABBBCDEF", to run. I looked in the Help documentation on Github. There are lots of references to *library*, but I couldn't see this error or instructions on how to add to the library. Thanks to Christophe and those who have contributed to this amazing project. Program: « 0. DUP 5. SQ NDUPN 2. + ROLL DUP SIZE DUP R→I UNROT 1 SWAP START DUP NUM 61. - DUP PICK 1. + SWAP 1. - UNPICK TAIL NEXT DROP 1 1. "" NUM START UNROT SWAP R→I DUP2 - UNROT COMB ROT * NEXT + » Mark. |
