Problem with the GMS template °′″
12-09-2024, 02:58 AM
Hello
Flags: Entry > Algebraic
Mode: Home
When placing the GMS template °′″ the cursor is placed after the degree symbol °|′″, it should be placed before |°′″
12-09-2024, 03:28 AM
RE: Problem with the GMS template °′″
(12-09-2024 02:58 AM)compsystems Wrote:  Hello
Mode: Home
You are using it wrong. You're supposed to key digits first (the whole hours or degrees), then press [°′″], then more digits (minutes), then press [°′″] again, and finally key the seconds (if any). The final [°′″] is optional. You never need to put °′″ on the edit line and then insert digits into it.
<0|ɸ|0>
-Joe-
12-09-2024, 03:55 PM (This post was last modified: 12-09-2024 04:05 PM by compsystems.)
The template ∎°∎′∎″ (accessed with the units button) specifies that the symbols °′″ are suffixes to ∎, so the cursor must be placed before the degree symbol |°
This problem only occurs when the input line is in non-pretty print mode, known here as algebraic mode as opposed to RPN mode.
