HP-35S Case Recommendations
12-13-2024, 08:13 PM
Hi all.
After more than a decade, my 35S case (the original hard case) is chiping/flaking off. Any recommendations would be greatly appreciated. Thanks |
12-13-2024, 11:42 PM
RE: HP-35S Case Recommendations
I recently found this case on amazon.
It was marketed as a "Hard EVA Carrying Case Compatible with HP 12C/HP 12CP Financial Calculator Storage case". However I suspect the images in the listing are digitally altered as it's a bit big for voyagers, at least on the elastic band side. Fortune shines on me though as it is nearly a perfect fit for the 35s and the voyagers fit much better behind the sleeve. If one would desire both in a single case. |
12-14-2024, 12:29 AM
Looks like a promising prospect.
