No UNROT on the HP-48G ?
11-01-2014, 02:53 AM
It's been a while since I wrote any program on the 48 (been on 50G and Prime and busy with my new HP-67)
I cannot find the UNROT command on the 48. I thought the RPL was the same between the 48G and 50G. I know the 50G has a lot of additional commands but I find UNROT pretty basic not to be included on the 48G. For the time being I use ROT ROT instead unless anybody has a better suggestion. François |
11-01-2014, 08:13 AM
(This post was last modified: 11-01-2014 08:14 AM by Joe Horn.)
RE: No UNROT on the HP-48G ?
That's right, the 48 does not have an UNROT command in its User RPL command set. It IS available in System RPL, however. For User RPL programs, ROT ROT or 3. ROLLD are equivalent to UNROT.
The other 50g stack commands not in the 48 are: DUPDUP, UNPICK, NIP, and NDUPN. <0|ɸ|0> -Joe- |
11-01-2014, 08:17 AM
<< ROT ROT >> 'UNROT' STO
Problem solved |
11-01-2014, 02:02 PM
RE: No UNROT on the HP-48G ? | |||
