Complex Prime Number Test
11-11-2014, 06:09 PM
(This post was last modified: 11-13-2014 01:21 PM by Eddie W. Shore.)
Program:
Code: EXPORT cisprime(z) Examples: cisprime(2-4*i) returns 0 cisprime(-2+5*i) returns 1 Source: http://mathworld.wolfram.com/GaussianPrime.html |
11-12-2014, 04:41 PM
RE: Complex Prime Number Test
Wow - never heard of those before. Thanks for teaching us!
I am puzzled - your program tests for 3mod4 of the non-zero component if the other is zero, but doesn't test the non-zero component for primality. So, for example, 0+/- 15i isn't a Gaussian prime as 15 isn't prime. Am I mistaken? |
11-12-2014, 05:31 PM
(11-12-2014 04:41 PM)Jim Horn Wrote: I am puzzled - your program tests for 3mod4 of the non-zero component if the other is zero, but doesn't test the non-zero component for primality. So, for example, 0+/- 15i isn't a Gaussian prime as 15 isn't prime. Am I mistaken? Quote:If a=0, then bi is a Gaussian prime iff |b| is an ordinary prime and |b|=3 (mod 4). Thus 15i is not a Gaussian prime since 15 is not an ordinary prime. However 5 is not a Gaussian prime though it is an ordinary prime since |5|=1 (mod 4). The complex factors of 5 are (2 + i)(2 − i). HTH Thomas |
11-13-2014, 01:23 PM
(11-12-2014 05:31 PM)Thomas Klemm Wrote:(11-12-2014 04:41 PM)Jim Horn Wrote: I am puzzled - your program tests for 3mod4 of the non-zero component if the other is zero, but doesn't test the non-zero component for primality. So, for example, 0+/- 15i isn't a Gaussian prime as 15 isn't prime. Am I mistaken? Thomas, Thanks for pointing out the glaring omission - much appreciated. The edited algorithm should be correct now. Eddie |
