[WP 34s] Strange behaviour of [alpha]XEQ
11-14-2014, 11:47 AM
Hello.
I'm trying to use the [alpha]XEQ function, but it doesn't work as (I) expected. From the manual I understand, that this function XEQtes the function with the name corresponding to the alpha-data stored in the register that is given as parameter. I tried the following code in in the emulator and in the real calculator (both version 3680): Code: **LBL'AXQ' I started both versions from RAM. The 'A' version works on my realbuild but not in the emulator. The 'B' version doen't work on both machines. The [alpha]XEQ produces "NO SUCH LABEL". Am I missing something or is this a bug? Regards Bernd |
11-14-2014, 10:02 PM
RE: [WP 34s] Strange behaviour of [alpha]XEQ
(11-14-2014 11:47 AM)Bernd Grubert Wrote: Am I missing something or is this a bug? Definitely something worth debugging. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
11-14-2014, 10:10 PM
RE: [WP 34s] Strange behaviour of [alpha]XEQ | |||
11-15-2014, 08:10 AM
Found the bug and exterminated it.
Should work properly in the next build. - Pauli |
11-15-2014, 02:02 PM
(11-15-2014 08:10 AM)Paul Dale Wrote: Should work properly in the next build.I've committed a new build to SF. Maybe before I assemble a new release package we should investigate the Y display optimizations. Is anybody willing to apply the patches? I can then do the building and packaging. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
11-15-2014, 06:22 PM
(11-15-2014 02:02 PM)Marcus von Cube Wrote:(11-15-2014 08:10 AM)Paul Dale Wrote: Should work properly in the next build.I've committed a new build to SF. Maybe before I assemble a new release package we should investigate the Y display optimizations. Is anybody willing to apply the patches? I can then do the building and packaging. I've committed the patches to both the 34S and the 31S. If something needs to be fixed or debugged, let me know, I'm happy to help. |
11-15-2014, 07:04 PM
(11-15-2014 06:22 PM)Bit Wrote: I've committed the patches to both the 34S and the 31S. If something needs to be fixed or debugged, let me know, I'm happy to help. I've updated the builds again. Happy testing! Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
11-15-2014, 08:37 PM
Hello all,
Thanks a lot for the bugfix. The new release works fine! Regards Bernd |
