CAS view
11-14-2014, 06:30 PM
CAS view
I've done something that I can't recover from...when integrating the definite integral of sin(x) from some value to another in CAS, I get the correct result. When I take the indefinite integral of sin(x), I get 0. It works if I use sin(X)dX. (It rewrites as SIN(X)dX) How do I restore CAS to correctly input my work?
11-14-2014, 06:43 PM
RE: CAS view
(11-14-2014 06:30 PM)lrdheat Wrote: I've done something that I can't recover from...when integrating the definite integral of sin(x) from some value to another in CAS, I get the correct result. When I take the indefinite integral of sin(x), I get 0. It works if I use sin(X)dX. (It rewrites as SIN(X)dX) How do I restore CAS to correctly input my work? Hi, try : purge(x) probably you have defined x:=0 |
11-14-2014, 07:08 PM
RE: CAS view
Thanks!
