PURGE function
11-16-2014, 04:26 PM
PURGE function
The function "purge(Var)" isn't working when I try to delete an user defined variable.
11-16-2014, 05:10 PM
RE: PURGE function
The user guide and On Calc help for purge() doesn't inform users about CAS and HOME limitations.
I imagine your example would be to purge(a HOME Var), not purge(a CAS Var). Home variables can be deleted using the Vars | User Variables key selection.
CAS variables can be purge()'d. Restart() purges all CAS variables and CAS settings, according to the user guide, for example.
-Dale-
