User Variable creation and deletion
12-26-2013, 04:51 PM
I created the following user variable in the home screen:
YOU:={1,2,3}
"YOU" shows up in the memory manager as a list and has 1,2,3 in it.
I then attempted to delete it using the "purge()" command.
Defn:
purge(Var) Unassigns a variable name. User manual P-409
Purge(YOU) ---> "No such variable YOU"
Am I missing something?
rcf
12-26-2013, 05:16 PM (This post was last modified: 12-26-2013 05:27 PM by Damien.)
RE: User Variable creation and deletion
if you want to delete "YOU", you have to go to the memory manager, select User Variables (by a double clic), now you have to scroll down the list until you find "YOU", then select it and choose suppr. in the menu bar.
You have got a memory manager without any usefull command to manage memory ! ( **** Where is my 28s !)
Damien.
12-26-2013, 05:17 PM
(12-26-2013 04:51 PM)Bob Frazee Wrote:  I created the following user variable in the home screen:
YOU:={1,2,3}
Defn:
rcf
purge() is for CAS variables only. The only way to delete variables created from the home view is via the memory browser (for now)
Graph 3D | QPI | SolveSys
12-26-2013, 08:00 PM
Thanks for answer. I didn't catch in the manual that the purge() command was only for the CAS system.
rcf
