HP Prime nagative angle problem
11-21-2014, 02:11 PM
Hi, I' using HP Prime (Application version: 20140702 v6031, Operating system version: V0.032.6030)
when I 'm in the Home View (Angle Measure: Degrees) and enter for example -0.2535241 and want to convert it in DMS (using decimal to sexagesimal conversion key) I get this 0°15'12.68676" without a minus. This is only problem when the angle is negative and it has 0°.
Is this a bug?
Attached File(s) Thumbnail(s)
11-21-2014, 03:08 PM
RE: HP Prime nagative angle problem
Yes, it is. Note that is is purely display purposes and the negative is actually there. If it falls between -1 and 0 this happens. Sorry! :-(
TW
11-22-2014, 04:01 AM
The negative sign of the angle is there, if you use it in the next calculation.
But if you grab it from the history screen after some intermediate calculations (say, a couple rows up), the negative sign will be lost.
11-22-2014, 10:00 PM
Ugh, I didn't notice it. Thanks for warning.
