Swiss Micros - anyone have one of these?
12-05-2014, 06:58 PM
http://www.swissmicros.com
The only discussion thread I was able to find is this one, which didn't get any replies on the subject. At first glance I wasn't that impressed. Just curious if anyone else has one, or has considered buying one. |
12-05-2014, 07:18 PM
(This post was last modified: 12-05-2014 07:19 PM by Massimo Gnerucci.)
RE: Swiss Micros - anyone have one of these?
(12-05-2014 06:58 PM)John Galt Wrote: http://www.swissmicros.com You didn't search hard enough... Have a look here I have v1 and v2 15CC along with the full line (10-11-12-16). Not on daily use but nice, *tiny* and fully compatible. Yes: the keyboard is what it is... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
12-05-2014, 09:58 PM
One thing cool is that it can be linked to a 15C simulator.
12-07-2014, 06:52 AM
There were a lot of swiss micro calculators at the last Allchwill meeting early november. I had one 15c of the second generation (a couple of years ago). The keys were hard to press and loose some of them. I tested one of these during the meeting pauses and the keyboard has been improved. I didn't personally like the bulky steel back case but the pouches and leather flip cover were really really nice. I think that there were no advertising of the improvements of these machines or i didn't notice it. Last comment: i am not connected to this company in any way. Thanks Giancarlo |
12-07-2014, 08:46 AM
There were quite some discussions about it. I have one from the first edition. Really cute, but I had to glue the posts to the back PCB after they came loose. Also, the mylar doesn't stick very well. The firmware is brilliant. It beats HPs 15C LE firmware hands down. No apparent bugs, an extra feature, and more memory registers.
12-07-2014, 10:00 AM
I've a couple of the first edition ones. Nice units, although they have a tricky keyboard at times, which I believe was improved in the second version. The firmware is perfect.
- Pauli |
12-13-2014, 09:13 PM
Isn't this some kind of massive patent violation?
12-14-2014, 01:57 AM
(12-13-2014 09:13 PM)John W Kercheval Wrote: Isn't this some kind of massive patent violation? Probably not as I suspect any patents that might apply here have long expired. Now copyright violation could be a possible issue since I beleive this device uses the microcode from the original calculator models. But that would only apply if HP provided a copyright notice for the code in their documentation or in the code itself. According to the following, it appears they did not. http://nonpareil.brouhaha.com/microcode_...ht_status/ |
12-14-2014, 08:43 AM
RE: Swiss Micros - anyone have one of these? | |||
