Complex matrices in programs
12-14-2014, 12:46 PM (This post was last modified: 12-14-2014 01:54 PM by Snorre.)
I want to define a constant complex matrix within a program. The program check is successful, but when running I get an "Insufficient memory" error.
Example:
  LOCAL x,y,z;  // Three identical matrices:
  x:=MAKEMAT((I,J),2,2);  // works, but not what I want
  y:=([[1,1],[2,2]],[[1,2],[1,2]]);  // works, but harder to read
  z:=[[(1,1),(1,2)],[(2,1),(2,2)]];  // wanted, but throws an error
I've searched the forum for a related answer and consulted the handbook, without success.
BTW: It doesn't make a difference if complex numbers are represented as a+i*b or (a,b).
Is that a bug or did I miss something?
If this is intentional behaviour, what would be the right way to do it?
Greetings
[EDIT] P.S. I've done it now by defining the matrix as a list and convert it, e.g. list2mat({{(1,1),(1,2)},{(2,1),(2,2)}}).
12-14-2014, 09:22 PM
RE: Complex matrices in programs
I played around with this as well, and can confirm the "insufficient memory error," if one tries to define the complex matrix directly inside the PPL program.
The best bet appears to be using list2mat (as you have already found out), e.g.,
LOCAL z:={1+1*i, . . . };
list2mat(z,2);
works just fine.
12-14-2014, 10:19 PM
By the way, did you try to define a complex matrix within a CAS program?
I get "Unmatch control word" error message.
Actually, I just discovered that I can't run any CAS programs any more, even the default template "new CAS program" without any alteration returns
program([],[],[0 0]).
Resetting the calc also doesn't help. Is this occurring because of the "insufficient memory message"?
12-14-2014, 10:36 PM (This post was last modified: 12-14-2014 10:36 PM by Han.)
(12-14-2014 10:19 PM)Helge Gabert Wrote:  By the way, did you try to define a complex matrix within a CAS program?
I can confirm the behavior with complex matrices in a non-CAS program. For CAS programs, I tried:
#cas
TEST():=
local l:=[[(1,2)],[(3,4)],[(5,6)]];
return l;
#end
This program ran fine in Home and CAS view (Firmware 6940).
Regarding complex matrices -- the parser actually converts any matrix into a list combined with a ListToMat() command. However, it seems to choke on complex matrices. You can see this by creating the following program that does nothing but declare and initialize two variables: a real value and a matrix and then debug it.
EXPORT TEST2()
local a:=0;
local l:=[[1,COS(a)],[4,5]];
This only occurs for matrices that do not consist of purely real numbers (in this case "COS(a)" not a real number in syntax).
Graph 3D | QPI | SolveSys
12-14-2014, 11:11 PM
I don't get that. My calc seems to be messed up.
I get (in CAS):
->LOCAL[l:=[[1+2*i [] ]:= [return l]
3+4*i
5+6*i]]
and in Home
program([],[],LOCAL[ [[1+2*i [] ]:=[0 [[1+2*i ])
3+4*i 3+4*i
5+6*i]] 5+6*i]]
I presume it is time to reinstall the firmware, but 6940 has been pulled.
12-14-2014, 11:56 PM
I don't think reflashing the firmware is necessary. You might try [On][Symb] and deleting the bad programs, followed by turning the calculator OFF and another [On][Symb] after turning it on.
12-15-2014, 12:07 AM
Thanks for the suggestions - - did all that, but it doesn't work.
Even creating a new CAS program from scratch without modifying
#cas
ABC():=
return 0;
#end
returns in Home
and in CAS
->[return 0]
Or maybe I'll just wait till the next firmware comes out . . .
12-15-2014, 12:59 AM
You can always reflash it by right-clicking on the calculator in the conn. kit and manually force a reflash. The firmware should presumably still be in the firmware folder unless you made modifications to it.
Another option is to press and hold [C][F][O] during the warmstart from using [On][Symb] to "format" your memory (doesn't affect firmware; just factory resets it). It's under #4.
12-15-2014, 01:15 AM (This post was last modified: 12-15-2014 01:31 AM by Helge Gabert.)
Thanks!!!
The firmware updates are on a different computer at another location - - I'll be there again in two weeks and can try then.
I'm trying #4 (flash utility) right now. Suboptions 1,2 or 3 (or all of them)? I did them all - - lost all my programs now (can restore, though) - - but still, running the CAS shell program returns program([],[],[0,0]) in Home, and ->[return 0] in CAS.
12-15-2014, 02:02 AM (This post was last modified: 12-15-2014 02:02 AM by Han.)
I tried running just an empty shell of a CAS program and got the same results. I would consider this a bug. Interesting, if you run the ABC() program with: ABC(0) then it runs "properly." I was expecting to get an argument count error, but even ABC(1,2,3) returns 0 (which means the code runs ok, but that it's completely ignoring argument count).
12-15-2014, 03:17 AM
Ah, now it works. Always run a CAS program with an argument (even if it is not needed). I don't get the "unmatch control word" error message anymore either.
#cas
ABC(k):=
return list2mat(z,2);
#end
Thanks for helping!
12-15-2014, 03:55 AM
Strange... now I can only replicate the behavior in Home view but not CAS view.
12-15-2014, 04:10 AM
Even with an argument? Or without? With an argument, I can run the CAS shell just fine (in both views). Without an argument, I get the underlying codes.
12-15-2014, 04:20 AM
(12-15-2014 04:10 AM)Helge Gabert Wrote:  Even with an argument? Or without? With an argument, I can run the CAS shell just fine (in both views). Without an argument, I get the underlying codes.
Without the arguments, that is. In Home view, I get program([],[],[0,0]); but in CAS I simply get 0 when I type ABC(). I did download some stuff onto my calculator, though. Would you humor me and download something (a program or app) to your calculator and see if it still misbehaves running CAS shell programs w/out an argument?
12-15-2014, 05:08 AM (This post was last modified: 12-15-2014 05:09 AM by Helge Gabert.)
I downloaded your Graph3D App.
In CAS, running the empty CAS shell, no arguments, I get ->[RETURN 0], if I execute ABC.
If I execute ABC(), I get 0, so no problem.
In Home, either way, ABC, or ABC(), I get program([],[],[RETURN 0]).
