HP program forms
11-23-2015, 10:57 PM
(This post was last modified: 11-25-2015 12:07 PM by PedroLeiva.)
Post: #41
RE: HP program forms
To all participants: I would like to contribute sending original forms for HP 25 and my own for HP 35s. For HP 25 two versions, English and Spanish. I hope they will serve some users. Pedro
11-24-2015, 06:53 AM
Post: #42
Very helpfull
Thank's for sharing Gérard. |
11-24-2015, 02:10 PM
Post: #43
(12-14-2014 10:35 PM)Sylvain Cote Wrote:All I get is a 404 error(12-14-2014 09:24 PM)Dieter Wrote: So I would like to ask which program forms have been available by HP or other sources. For instance, has there been a version for the Spices? And maybe somewhere there is a source for PDF forms ?-) Tom L Tom L Cui bono? |
11-24-2015, 03:36 PM
Post: #44
RE: HP program forms | |||
11-24-2015, 04:11 PM
Post: #45
(11-23-2015 10:57 PM)PedroLeiva Wrote: To all participants: I would like to contribute sending original forms for HP 25 and my own for HP 35s. For HP 25 two versions, english and Spanish. I hope they will serve some users. Pedro 35s Form is quite nice and complete; I don't think I've seen 35S forms before. Thanks for the work to build it and share it here. --Bob Prosperi |
11-25-2015, 01:50 PM
(This post was last modified: 11-25-2015 01:52 PM by Sylvain Cote.)
Post: #46
I have updated some of the links from the original posts and here they are grouped together.
HP-35, 55, 25, 65, 67 and 41 Forms HP-35/45 Key Sequence Form & HP-55/25/65/67 Program Form HP-65/67/97/41C Program Submittal for Users Library HP-35 Key Sequence Empty form HP-35 Key Sequence Filled form (file need to be updated, need to remove the filigrane) I have created a hpmuseum folder in my dropbox public account for file safekeeping. In the coming days/weeks, I will move all the files referenced in this site to this folder and update all the links of my posts accordingly. I have tested the above links and they works for me. If you have any issue, please let me known. Best regards, Sylvain |
11-28-2015, 09:44 AM
Post: #47
Hi Sylvain,
Run pretty well now for me. Thank's Gérard. |
05-17-2016, 11:11 PM
Post: #48
Here some more HP 67/97 & 41 Program Forms, compile from: http://saundby.com/electronics/CodingForms/
I hope they have not already been uploaded, Pedro |
06-14-2018, 10:19 PM
Post: #49
Well, well, well... I might be a little late to the party, but these just made my day. Thank you!
06-14-2018, 10:21 PM
Post: #50
(11-25-2015 01:50 PM)Sylvain Cote Wrote: I have updated some of the links from the original posts and here they are grouped together. As you probably know, at least some of these links are dead. I think it is worth preserving this material and would greatly appreciate it if you would update the links so I can catch these documents. Thanks! |
06-14-2018, 11:54 PM
(This post was last modified: 06-15-2018 12:05 AM by Sylvain Cote.)
Post: #51
(06-14-2018 10:21 PM)drdbthompson Wrote: As you probably know, at least some of these links are dead.You should be thanking DropBox who has changed their file sharing policies. Here some of them ... Key Sequence Forms Key Sequence Forms with Data Entry Program Forms
Sylvain edit: add Key Sequence Forms with Data Entry section |
06-15-2018, 11:43 PM
Post: #52
03-22-2021, 05:38 PM
Post: #53
I have started a Google Sheet accessible by everyone containing two tabs (currently). A Program Listing and Registers, Status, Flags, and Assignments forms. Please copy, use, and comment so I may improve these for use by everyone.
Forum Post Google Sheet HP48GX, HP42s and DM42. |
03-23-2021, 01:07 AM
Post: #54
To make these REALLY useful, we need a custom font for the HP keys (although I’m not sure how to make using such a font easy!). I do have an old copy of Fontographer and hardware to run it…).-kby
03-23-2021, 01:21 AM
Post: #55
How hard can it be to make a font? (Famous last words). I may look into trying this though I have no real idea what this entails.
03-23-2021, 01:46 AM
Post: #56
(03-23-2021 01:21 AM)DM48 Wrote: How hard can it be to make a font? (Famous last words). I may look into trying this though I have no real idea what this entails.OMG, how many times I have said that, you may be in for some surprises. Do not forget that you have a wide audience that use Windows, macOS or Linux machines and that the font must works on all of them. Also, because macOS UI rendering is based on PDF, font requirements are very stringent and not that easy to satisfy. But do not let these little things stop you, go ahead and make a great HP keys font! |
03-23-2021, 01:49 AM
Post: #57
I’m a gluten for punishment. Does anyone have an example of all the characters used and would need to be included in the font?
03-23-2021, 02:56 AM
Post: #58
You made me doing some research on font creation programs for macOS and I found Glyphs.
This Austria made application seems to be THE one to use to create OpenType fonts (OTF, TTF, etc) the easy way. I do not have time right now, but I will definitively try it in the near future. |
03-23-2021, 10:51 AM
Post: #59
I’m on a Mac, too. ?
User(s) browsing this thread: 8 Guest(s)
