Change
12-16-2014, 02:55 PM
(This post was last modified: 12-16-2014 02:56 PM by hp41cx.)
Change
I need on diskette 5 1/4 for use in 82901M the following programs
83/85 Games II Pac 83/85 Standard Pac 86/87 WordStar 3.0 I ship as payment Systems Analyst 48G+/58C/85B/PC1500A TH-78A/DooGee S9 Focal & All BasicĀ“s |
12-20-2014, 04:05 AM
RE: Change
Diskette images of all these software packages are available at http://www.hpmuseum.net the wordstar package require the CP/M card and software.
12-20-2014, 04:40 AM
RE: Change
(12-20-2014 04:05 AM)Paul Berger (Canada) Wrote: Diskette images of all these software packages are available at http://www.hpmuseum.net the wordstar package require the CP/M card and software. The issue is that the images on hpmuseum.net are for 3.5" disks and the 82901M uses 270K 5.25" disks. Using TeleDisk I was able to copy the 3.5" images to 5.25" HD disks, but they couldn't be read by the 82901M. |
12-20-2014, 02:38 PM
RE: Change
One possible solution is to use HPdrive to emulate a 3.5 inch diskette. There is a utility to covert TD0 images to a format that HPdrive can use. From there you could copy all the files on the images to a 5.25 diskette. For the wordstar diskette you may need to copy the files under CP/M, however copying them in the BASIC OS may work to.
