Terminal alternative
12-19-2014, 05:13 PM (This post was last modified: 12-25-2014 04:24 PM by Snorre.)
this program is borrowed from the german HP-Prime forum.
It was written because the builtin terminal has some drawbacks (which were introduced in some recent firmware update) -- mainly very size-limited line buffer and not displaying the most recent PRINTed line.
Beware: This program does not break long lines as the builtin terminal would do, and G9 is used as drawing buffer.
Program "TERM":
EXPORT LiveView:=1;  // Visible while outputting?
BackColor:=RGB(0,0,0);
TextColor:=RGB(0,255,0);
BarBColor:=RGB(0,128,0);
BarFColor:=RGB(64,255,64);
Capacity:=9999; // = max list size
FontSize:=2;
Buffer:={};
LastTouchY,Top;
LineHeight()
BEGIN 2*FontSize+10; END;
TotalHeight()
BEGIN SIZE(Buffer)*LineHeight; END;
MaxTop()
BEGIN MAX(TotalHeight-240,0); END;
Redraw(top)
  // Draw buffered lines
  LOCAL h:=LineHeight;
  LOCAL n:=SIZE(Buffer),
        k:=IP(top/h),
        y:=-(top MOD h);
  DIMGROB_P(G9,320,240,BackColor);
  WHILE k<n AND y<240 DO
    TEXTOUT_P(Buffer(k:=k+1),G9,0,y,
              FontSize,TextColor);
    y:=y+h;
  // Draw scrollbar
  LOCAL t:=TotalHeight;
  IF t≥240 THEN
    y:=240*top/t;
    RECT_P(G9,318,0,319,239,BarBColor);
    RECT_P(G9,318,y,319,y+240²/t,BarFColor);
  // Show
  BLIT(G9);
  Top:=top;
MoveTo(top)
  top:=MAX(MIN(top,MaxTop),0);
  IF top≠Top THEN Redraw(top); END;
Resize(fontSize)
  fontSize:=MAX(MIN(fontSize,7),1);
  IF fontSize≠FontSize THEN
    FontSize:=fontSize;
    Redraw(MIN(Top,MaxTop));
HandleTouch(touch)
  IF touch(1)≤#1 THEN
    LOCAL y:=B→R(touch(3));
    CASE
      IF touch(2)≥#300d
      THEN MoveTo(y/240*TotalHeight); END;
      IF touch(1)=#1
      THEN MoveTo(Top+LastTouchY-y); END;
    LastTouchY:=y;
HandleKey(code)
  CASE
    IF code=7  THEN MoveTo(0); END;
    IF code=8  THEN MoveTo(MaxTop); END;
    IF code=2  THEN MoveTo(Top-80); END;
    IF code=12 THEN MoveTo(Top+80); END;
    IF code=42 THEN Resize(1); END;
    IF code=43 THEN Resize(2); END;
    IF code=44 THEN Resize(3); END;
    IF code=37 THEN Resize(4); END;
    IF code=38 THEN Resize(5); END;
    IF code=39 THEN Resize(6); END;
    IF code=32 THEN Resize(7); END;
    IF code=45 THEN Resize(FontSize-1); END;
    IF code=50 THEN Resize(FontSize+1); END;
// Clear the terminal buffer.
EXPORT CLEAR()
  Buffer:={};
  IF LiveView THEN Redraw(0); END;
// Add a single line or a list of lines to terminal buffer.
EXPORT OUT(data)
  LOCAL s:=SIZE(Buffer)+
           IFTE(TYPE(data)=6,SIZE(data),1);
  IF s>Capacity THEN
    Buffer:=SUB(Buffer,s-Capacity+1,Capacity);
  Buffer:=CONCAT(Buffer,data);
  IF LiveView THEN Redraw(MaxTop); END;
// Show the terminal buffer contents.
EXPORT SHOW()
  LOCAL inp;
  REPEAT
    IF TYPE(inp:=WAIT(-1))=6
    THEN HandleTouch(inp); inp:=-1;
    ELSE HandleKey(inp); END;
  UNTIL inp=30 OR inp=4;  // leave on [Enter] or [Esc]
Usage:
Replace "PRINT()" by "TERM.CLEAR()", "PRINT(data)" by "TERM.OUT(data)", and call "TERM.SHOW()" to view the buffer. (Omit the prefix "TERM." if "CLEAR", "OUT", "SHOW" don't collide with other function names).
If "TERM.LiveView" is set to 0 the program won't display anything until "SHOW()"ed.
Scroll to top/bottom by cursoring left/right, or otherwise 1/3-page up/down.
Keys [1],...,[7],[+],[-] will change font size.
Test program "TERMTEST" for comparing builtin terminal vs. "TERM":
EXPORT TERMTEST1()
  PRINT();
  LOCAL n:=0,s;
  REPEAT
    s:=STRINGFROMID(n:=n+1);
    PRINT(n+": "+s);
  UNTIL s="LASTSTRING";
EXPORT TERMTEST2()
  CLEAR();
  LOCAL n:=0,s;
  REPEAT
    OUT(n+": "+s);
  SHOW();
Any improvements are very welcome. Ideas: handle line breaks, long lines, tabulators, highlight numbers, better type handling in general etc.
This program might become obsolete eventually, when the Prime's builtin terminal is upgraded.
Greetings
[EDIT] Thread renamed to not disrupt the sequence of "HP Prime: ..." articles by E. W. Shore when alphabetically sorted.
06-04-2017, 06:33 PM (This post was last modified: 06-04-2017 06:57 PM by Freire.)
RE: Terminal alternative
Althought this is an old post, this Terminal is very good.
Suggestions to code:
-Scroll bar a bit larger and bit more precision by moving it through it's midpoint instead of top point.
-Change in OUT(data) to deal with strings that are larger than a Line, to be printed in 2 lines.
-Fancy Header.
PS: This is not the most elegant and is a bit imprecise but works better than before.
The way of cutting strings into two lines is far from good.
New Code:
//  Author:     Snorre
//  Version:    1.01
//  Update:     04 June 2017
//  Firmware:   10637 -> 29/08/2016
FontSize:=2;
Buffer:={};
LastTouchY,Top;
LineHeight()
LineWidth()
BEGIN IP(-15.5*LN(FontSize)+63.9); END;
TotalHeight()
ScrollHeight()
BEGIN 240²/TotalHeight; END;
MaxTop()
Redraw(top)
    k:=IP(top/h),
    y:=-(top MOD h);
        y:=y+h;
    // Draw scrollbar
    IF t≥240 THEN
        y:=240*top/t;
        RECT_P(G9,316,0,319,239,BarBColor);
        RECT_P(G9,316,y,319,y+240²/t,BarFColor);
    // Show
    BLIT(G9);
    Top:=top;
MoveTo(top)
Resize(fontSize)
        FontSize:=fontSize;
HandleTouch(touch)
    IF touch(1)≤#1 THEN
        CASE
            IF touch(2)≥#300d
            THEN MoveTo((y-ScrollHeight/2)/240*TotalHeight); END;
            IF touch(1)=#1
        LastTouchY:=y;
HandleKey(code)
    CASE
EXPORT CLEAR()
    Buffer:={};
EXPORT OUT(data)
    LOCAL w:=LineWidth;
    LOCAL temp_data,temp_datas;
    IF TYPE(data)==6 THEN
        FOR i FROM 1 TO SIZE(data) DO
            IF (DIM(data(i))>w) THEN
                temp_data:=SUB(data,i+1,SIZE(data));
                temp_datas:=data(i);
                data(i):=LEFT(data(i),w);
                data:=CONCAT(SUB(data,1,i),RIGHT(temp_datas,DIM(temp_datas)-w));
                data:=CONCAT(data,temp_data);
        ELSE
        IF (DIM(data)>w) THEN
            temp_datas:=data;
            data:={};
            data:=CONCAT(data,LEFT(temp_datas,w));
            data:=CONCAT(data,RIGHT(temp_datas,DIM(temp_datas)-w));
    IF s>Capacity THEN
EXPORT SHOW()
    LOCAL inp;
    REPEAT
Changed Parts:
//  Author:     Snorre
//  Version:    1.01
LineWidth()
ScrollHeight()
    LOCAL w:=LineWidth;
        ELSE
            temp_datas:=data;
            data:={};
06-06-2017, 07:58 PM (This post was last modified: 06-06-2017 08:05 PM by compsystems.)
2 new cmds
PHP Code:
//  File: TERM.hpprgm
//  Author:     Snorre
//  Version:    1.02
EXPORT LiveView:=0;  // Visible
EXPORT FontSize:=3;
Capacity:=9999// = max list size
Buffer:={};
LastTouchY,Top;
LineHeight()
BEGIN 2*FontSize+10END;
LineWidth()
TotalHeight()
BEGIN SIZE(Buffer)*LineHeightEND;
ScrollHeight()
BEGIN 240²/TotalHeightEND;
MaxTop()
Redraw(top)
k:=IP(top/h),
y:=-(top MOD h);
    WHILE
k<AND y<240 DO
y:=y+h;
// Draw scrollbar
    IF
t≥240 THEN
        y
:=240*top/t;
// Show
BLIT(G9);
Top:=top;
MoveTo(top)
    top
    IF
Resize(fontSize)
    fontSize
    IF
        FontSize
:=fontSize;
HandleTouch(touch)
IF touch(1)#1 THEN
        CASE
            IF
touch(2)#300d
            IF
touch(1)=#1
LastTouchY:=y;
HandleKey(code)
CASE
        IF
        IF
        IF
        IF
        IF
        IF
        IF
        IF
        IF
        IF
        IF
        IF
        IF
EXPORT CLEAR()
    Buffer
    IF
EXPORT OUT(data)
    LOCAL w
:=LineWidth;
    IF
TYPE(data)==6 THEN
            IF (
DIM(data(i))>wTHEN
                temp_data
        ELSE
        IF (
DIM(data)>wTHEN
            temp_datas
:=data;
data:={};
    IF
s>Capacity THEN
        Buffer
    IF
EXPORT SHOW()
    Redraw
(MIN(Top,MaxTop));
LOCAL inp;
REPEAT
            THEN HandleTouch
(inp); inp:=-1;
        ELSE
// Set
EXPORT SET_VISIBLE_TERM(flag)
IF flag=
    THEN LiveView
:=1;
    ELSE
LiveView:=0;
// Set
EXPORT SET_FONTSIZE_TERM(size_f)
    FontSize
:=size_f;
END
file: testTerm.hpprgm
PHP Code:
//file: testTerm.hpprgm
EXPORT TERMTEST1()
PRINT();
LOCAL n:=0,s;
REPEAT
    s
    PRINT(
n+": "+s);
//wait(0.1);
UNTIL n=2995;
//return {s,n};
return "Done";
EXPORT TERMTEST2()
  TERM
.CLEAR();
LOCAL n:=0,s;
TERM.SET_VISIBLE_TERM(1);
TERM.SET_FONTSIZE_TERM(3);
REPEAT
    s
TERM.OUT(n+": "+s);
//wait(0.1);
UNTIL n=2995;
TERM.SHOW();
//return {s,n};
return "Done";
END
