Virtual calculator freeze with CK. Rev 6975
12-22-2014, 10:18 AM
(This post was last modified: 12-22-2014 10:47 AM by Gilles.)
I have a problem with the rev 6975. It worked in the beginning but don't works now.
The problem is : -The virtual calulator works fine -The connectivity kit seems to work fine but when I tries to push (for example it freezes in others cases) a program from the CK to the virtual calculator then the virtual calculator freezes I can push the virtual keybord but nothing happens. The only thing is to reset the virtual calc, with the same problem after... I tried to desinstall/reinstall all but always the same problem. Is there some directory or keys register entries to delete manually ? |
12-30-2014, 01:00 AM
RE: Virtual calculator freeze with CK. Rev 6975
I've not been able to reproduce this on my end and honestly have no idea what could be going on. Still happening to you?
