Programming in CAS MODE CAS version DEC 2014 ...
01-03-2015, 06:20 AM (This post was last modified: 01-03-2015 06:57 AM by compsystems.)
Hi, the following code is an initial version of a library of complex functions
Thanks HPprime TEAM, improve the CAS environment =)
/!\ The CAS functions must be covered in a block # cas ... # end
and must be run from the entry line, not because they do not operate from the editor programs =(
file: complexAlgebraLibrary.hpprgm
#cas
    // © complex algebra library
    // © complex numbers and functions
    // © version 0.01 January 2015
    // © By JaiMeza www.jaimeza.org
    // © test CAS Version: 1.1.2-11 and Operating System: version 6.2.9200
    cplxA := 3+4*; // numeric complex 3+4*i
    cplxB := x+y*; // symbolic complex
    // © modulus of a complex number given in standard form
    modulus(z)
    begin
        return abs(z);
    end;
    // © real part of a complex number given in standard form
    realPart(z)
    begin
        return re(z);
    end;
    // © imaginary part of a complex number given in standard form
    imagPart(z)
    begin
        return im(z);
    end;
    // © conjugate of a complex number given in standard form
    conjugat(z)
    begin
        return conj(z);
    end;
    // © argument of a complex number given in cartesian form (x,y)
    cartArg(x,y)
    begin
        // © arguments (x, y)
        if getMode_angle() == "RADIAN" then
            return ((π/2)*sign(y) - atan(x/y));
            else
            return ((90)*sign(y) - atan(x/y));
        end;
    end;
    argument(z)
    begin
        Return arg(z)
    end;
    // © conversion from polar to cartesian form
    polarRθtoCartXY(r, θ)
    begin
        return ( [[ r*cos(θ), r*sin(θ) ]] )
    end;
    exeSample()
    begin
        cplx1 := 3+4*;
        cplx2 := x+y*;
        print();
        print( "*** Examples ***" ); freeze;
        print( "cplx1 = " + cplx1 );
        print( "cplx2 = " + cplx2 );
        print("");
        print( "modulus( " + cplx1 + ") = " + modulus(cplx1) );
        print( "modulus( " + cplx2 + ") = " + modulus(cplx2) );
        print("");
        print( "realpart( " + cplx1 + ") = " + realPart(cplx1) );
        print( "realpart( " + cplx2 + ") = " + realPart(cplx2) );
        print("");
        print( "imagpart( " + cplx1 + ") = " + imagPart(cplx1) );
        print( "imagpart( " + cplx2 + ") = " + imagPart(cplx2) );
        print("");
        print( "conjugat( " + cplx1 + ") = " + conjugat(cplx1) );
        print( "conjugat( " + cplx2 + ") = " + conjugat(cplx2) );
        print("");
        print("RADIAN");
        setMode_angle( "RADIAN" );
        print( "polarRθtoCartXY( 5, 0.927295218002_r ) = " + polarRθtoCartXY( 5, 0.927295218002) );
        print( "cartArg( 3, 4 ) = " + cartArg( 3, 4 ) );
        print( "argument( " + cplx1 + ") = " + approx( argument(cplx1) ) );
        print("");
        print("DEG");
        setMode_angle( "DEG" );
        print( "polarRθtocartXY( 5, 53.1301023542_° ) = " + polarRθtoCartXY( 5, 53.1301023542) );
        print( "cartArg( 3, 4 ) = " + cartArg( 3, 4) );
        freeze;
        return "Done";
    end;
#end
//#home
    export getMode_angle()
    begin
        if AAngle == 1 then
            return( "RADIAN" );
        else
            if AAngle == 2 then
                return( "DEG" );
            else
              return( "SYS_ANGLE" );
            end;
        end;
    end;
    export setMode_angle( angle_mode )
    begin
        if angle_mode == "RADIAN" then
            AAngle := 1
        else
            if angle_mode == "DEG" then
                AAngle := 2
            else
              AAngle := 0
            end;
        end;
    end;
//#end;
Run on ENTRY LINE the function exeSample() to show the operation of the functions I'm programming
PD: The character "i" and not displayed on this forum =(, and in the PC program editor (Hp Conn Kit) a empty box is shown =(
I think it is a problem of the font text, please confirm this on their computers.
Please provide an updated text font
Note: the function list are displayed by pressing the [VAR] key after CAS Menu
To edit function by function press MEM [Shift]+[Tools], as a requirement HPPrime TEAm please make it show in full screen, currently editing in one line =(, another request is to allow copy all output from the terminal view, the purpose of pasting it into a tutorial or in this forum for example
