Massaging output of 50g's FACTORS command
01-03-2015, 07:12 AM
For a value or expression, FACTORS returns a list of prime factors and their multiplicities: 1944 FACTORS returns {3 5. 2 3.}, for example.
How can I split that list into two, one {3 2} a list of the prime factors and the other {5. 3.} a list of their respective multiplicities? Some little RPL program will presumably do it. This should be a few seconds' worth of fun for someone! |
01-03-2015, 03:08 PM
(This post was last modified: 01-03-2015 03:09 PM by Gilles.)
RE: Massaging output of 50g's FACTORS command
Hi Peter, you can do for example :
Code: DUP |
01-03-2015, 05:27 PM
Hi Gilles,
Thanks for that nice program. Is the leading "1." the type against which each member of the list is compared? Peter |
01-03-2015, 05:32 PM
(This post was last modified: 01-03-2015 05:38 PM by C.Ret.)
Hi, another way is to duplicate the list element by element into two distinct lists.
To separate factors from exponents, the process alternates the positions of the two lists during construction. Code: SPLIPT: The factors lsit { 3 5. 2 3.} will result in { 2 3 } and { 3. 5.} lists. The list { y 5 p 1 p 0 a 2 H } will be split into the two lists 1:{ H a p p y } and 2:{ 2 0 15 }. This last example is of course a season best greetings pretext. So { y 5 p 1 p 0 a 2 H } SPLIT to everybody here !! |
01-03-2015, 06:16 PM
Hello C.Ret,
That's also nice. I had thought vaguely about GET, but not about GETI. Peter |
01-03-2015, 09:16 PM
(This post was last modified: 01-03-2015 09:21 PM by Gilles.)
(01-03-2015 05:27 PM)Peter Murphy Wrote: Hi Gilles, The leading "1." is the number of arguments taken from the list for the DOSUBS command. That means that the sequence « DUP TYPE NOT {DROP} IFT » DOSUBS takes elements in the list one by one and returns a list with your example : { 3 5. 2 3.} 3 DUP TYPE NOT {DROP} IFT is executed, returns nothing (3 is TYPE 28.) 5. DUP TYPE NOT {DROP} IFT is executed, returns (5. is TYPE 0). 2 DUP TYPE NOT {DROP} IFT is executed, returns nothing 3. DUP TYPE NOT {DROP} IFT is executed, returns 3. So DOSUBS -> returns { 5. 3. ) For example { "a" "b" "c" "d" } 3. « + + » DOSUBS will return { "abc" "bcd"} that means :take the arguments from the list 3 by 3 and concatenate {"a "b" "c" + +, "b" "c" "d" + +} |
01-03-2015, 09:35 PM
Gilles,
Thanks for your kindly and detailed help. This Forum is an excellent place. Peter |
01-04-2015, 09:58 AM
(This post was last modified: 01-04-2015 10:23 AM by Gilles.)
I wondered if it was possible to split a list with only one DOSUBS and found this way :
Code: 1. « NSUB 1. == {{}{} ROT} IFT + SWAP » DOSUBS {"a" "b" "c" "d" "e" "f" "g" "h" } -> { { "b" "d" "f" "h" } { "a" "c" "e" "g" } } And to get the result in right order both with odd or even number of elements in the list Code:
01-07-2015, 10:12 PM
(This post was last modified: 01-07-2015 10:21 PM by Han.)
The code below basically changes the list into an array, then converts to a list of row vectors that are reverse-sorted, and then converted back to a matrix. Finally a transpose gets the desired form.
Code: « Graph 3D | QPI | SolveSys |
01-08-2015, 11:11 AM
As we're talking about the HP 49G it's easy to write a programme that doesn't first make a list of factors & powers & then has to seperate them.
:: FPTR2 ^CK1Z FPTR2 ^MSQFF NULL{} DUPROT #2/ ZERO_DO 4ROLL >TCOMP SWAPROT >TCOMP SWAPLOOP ; Oh for such flexibility on other platforms! |
User(s) browsing this thread: 5 Guest(s)
