Should Global Variables Retain Their Values After Program Execution
01-12-2015, 04:30 AM (This post was last modified: 01-12-2015 04:40 AM by SEzzell.)
I was working on my first HP Prime program and can get the program to produce output with correct answers for values I am seeking, however, I desire to be able to continue using the values stored in the global variables I created when the program is run with the data I input. After running, the variables are listed as user variables for my program, but have not retained the values shown in the output statements. It appears the values are all zero. I have attached a text file with the code and would appreciate any help.
Attached File(s)
.txt  Section_Property.txt (Size: 3.71 KB / Downloads: 22)
01-12-2015, 04:34 AM (This post was last modified: 01-12-2015 04:34 AM by Kevin Ouellet.)
RE: Should Global Variables Retain Their Values After Program Execution
Yes, IMHO they should, or there should be a clear tutorials on how to do it. Unfortunately, they don't right now.
-Dream of Omnimaga
https://djomnimaga.music-2000.com
01-12-2015, 06:26 AM
It appears you declared a few variables as global via the export command at the top. However, you then also declared local variables of the same name, which of course have higher priority. Thus, the global variables are never actually updated. Remove the variables whose value you wish to retain from the LOCAL statement (line 8).
Graph 3D | QPI | SolveSys
01-13-2015, 03:53 AM
I made the changes you suggested, removing the local declaration from the scope of the program and used just the export keyword to make the variables global. After running some test data, I found that I could use those values stored in the global variables in later calculations. This is just the way I wanted the program to work!
This was very helpful and I appreciate your assistance Han.
01-13-2015, 03:54 AM
Glad to hear that it worked for you; keep in mind that anytime you edit your program, though, those global variables are reset.
