Pioneer display suddenly wonky
01-12-2015, 05:33 PM (This post was last modified: 01-12-2015 05:35 PM by Bill Platt.)
Has anyone had this happen?
I was using my 32sii as usual, all fine, and then went to do another calculation and got this:
https://www.dropbox.com/s/mipnc3t4of203x...4.JPG?dl=0
01-12-2015, 06:01 PM
RE: Pioneer display suddenly wonky
Nasty! What have you done to try to reset it? Remove the battery and short the contacts is what I would recommend as a the first thins to do. If that doens't fix it what happens if you press down just under the display window?
-katie
01-12-2015, 08:14 PM
It looks like you have lost several scan lines. This looks pretty much like a contact problem between the LCD and the main board.
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
01-13-2015, 02:48 AM
(01-12-2015 08:14 PM)Marcus von Cube Wrote:  It looks like you have lost several scan lines. This looks pretty much like a contact problem between the LCD and the main board.
It does look that way, but Bill made it sound like it happened mid-use, like it was on his desk and hadn't been moved between calculations. So I thought a power cycle would be a good place to start.
Bill, let us know the status of this......
-katie
01-13-2015, 03:50 AM
That was interesting, I started with Katie's suggestion--and I got the happy "Memory Clear" announcement. And then for some reason I took the batteries out to see if it wasn't a lark, put them back in, and it was back to silliness again but a different pattern. So I took them out again, and shorted again (I love little swiss army knives-and the contacts are easy to short with the nail file) and it came alive. Still alive now.
01-13-2015, 04:22 AM
(01-13-2015 03:50 AM)Bill Platt Wrote:  That was interesting, I started with Katie's suggestion--and I got the happy "Memory Clear" announcement. And then for some reason I took the batteries out to see if it wasn't a lark, put them back in, and it was back to silliness again but a different pattern. So I took them out again, and shorted again (I love little swiss army knives-and the contacts are easy to short with the nail file) and it came alive. Still alive now.
Yeah! Score another victory for the good old "re-boot" method of debugging/repair.
-katie
01-13-2015, 05:37 AM
The dreaded ESD strikes again???
01-13-2015, 08:38 AM (This post was last modified: 01-13-2015 08:38 AM by ElectroDuende.)
How old are the batteries? I've sometimes seen strange behaviours when battery level is low in several HP (and non HP) machines.
