Latest PDF Manuals
01-13-2015, 11:28 PM
Latest PDF Manuals
Could someone please advise me where I can download the latest PDF manuals for the CK, VC, & HPP. I just completed the latest update 6975 and wanted to update my tablet with the latest manuals for reference. I see allot of different versions on the net.
Thank You,
minus1
01-13-2015, 11:54 PM
RE: Latest PDF Manuals
Have you tried the Help menu in the PC applications?
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
01-13-2015, 11:57 PM
If you can wait a few days, they will be going up in the http://ftp.hp.com/pub/calculators/Prime location shortly (provided nothing funny happens).
If you installed the emulator, the latest are in the install directory.
TW
01-14-2015, 08:25 PM
Tim, thanks for the the feedback.
01-14-2015, 08:41 PM
Tim, thanks for the feedback.
minus1
01-14-2015, 11:01 PM
(01-14-2015 08:41 PM)minus1 Wrote:  Tim, thanks for the feedback.
minus1
It is there now if you'd like.
TW
01-15-2015, 06:23 AM
(01-13-2015 11:57 PM)Tim Wessman Wrote:  If you can wait a few days, they will be going up in the http://ftp.hp.com/pub/calculators/Prime location shortly (provided nothing funny happens).
It looks like the forum software has an interesting issue with non-http links. The link actually starts with ftp, not http.
01-15-2015, 01:36 PM (This post was last modified: 01-15-2015 01:36 PM by rprosperi.)
It's a well known issue with the Forum software. It prepends the http:// to whatever one inserts, so no (simple) way to avoid it. Rarely, some folks edit the link before final post, but most often not, and frequent users know to edit the subsequent browser line to remove the initial http.
01-15-2015, 02:26 PM
(01-14-2015 11:01 PM)Tim Wessman Wrote:  It is there now if you'd like.
Tim, the French User's Guide on the ftp server (named User_Guide_FRA_2014_12_03_1.pdf) is an old version from November 2013, not the new one coming with the latest version of the Virtual Calculator.
01-15-2015, 02:51 PM (This post was last modified: 01-15-2015 07:34 PM by Tim Wessman.)
(01-15-2015 02:26 PM)Didier Lachieze Wrote:  User_Guide_FRA_2014_12_03_1.pdf) is an old version from November 2013, not the new one coming with the latest version of the Virtual Calculator.
Interesting. That probably means the same one is in the emulator install since they both pull from the same source directory. Will get it fixed. Thanks!
[edit] nope, emulator release and isos have the correct french. It is just the ftp file that was wrong. Whew! :-)
TW
