Key unassign en mass in HP Prime.
01-16-2015, 12:16 AM
Is there an easy way to unassign all keys en mass in HP Prime. Thank you.
01-16-2015, 07:51 AM
RE: Key unassign en mass in HP Prime.
The manual suggests to deactivate the user mode (pg. 511).
01-16-2015, 05:09 PM
(01-16-2015 12:16 AM)John P Wrote:  Is there an easy way to unassign all keys en mass in HP Prime. Thank you.
Not really. Keys are not "assigned" like the 48 style but rather programs are created for them and *when that program function is in scope it will be used*. Basically, if you define a key in a user program (which is global) then it will be global. If you define it in an app program then it will be used only when that app is active.
If you want to turn then off, turning off user keys will do that as stated.
TW
01-16-2015, 05:39 PM
I think that is good idea Tim sort of explained. I will play with it to get the hang of it.
Thanks to everybody.
01-17-2015, 12:14 PM
Assuming the key assignments are in a single program file.
1) What about simply deleting the program as a definitive key mass unassign ?
2) If the unassign is to be temporary, what about simply introducing an error in the program file in order to make compilation fail ?
Patrice
“Everything should be made as simple as possible, but no simpler.” Albert Einstein
01-17-2015, 04:28 PM (This post was last modified: 01-17-2015 04:28 PM by rprosperi.)
(01-17-2015 12:14 PM)patrice Wrote:  2) If the unassign is to be temporary, what about simply introducing an error in the program file in order to make compilation fail ?
Clever Patrice!! Saves much time this way
01-17-2015, 08:57 PM
(01-17-2015 12:14 PM)patrice Wrote:  Assuming the key assignments are in a single program file.
I have a prgm. to assign some keys named for example "assignxxx" and to unassign I rename copy of "assignxxx" to "unassignxxx" and delete what comes after each "return ???;". It does the job for now. Thanks.
