WP34s on iPhone
01-24-2015, 11:09 AM
WP34s on iPhone
Hello All,
This may be a dumb question but how do you get rid of the pull-down register/stack display in the WP34s iPhone app? No amount of poking or swiping seems to work :-( I'm using an iPhone 5c -- which I just got a couple of days ago, so of course the first thing I did was load some calculator apps to play around with :-) Thanks for any help, Paul |
01-24-2015, 03:16 PM
RE: WP34s on iPhone
(01-24-2015 11:09 AM)pdo Wrote: This may be a dumb question but how do you get rid of the pull-down register/stack display in the WP34s iPhone app? No amount of poking or swiping seems to work :-( Upon further experimentation I did manage to make it go away, but not in a reliable way. In fact, both making it appear and disappear seem to be very difficult. Maybe there is some slight problem with the latest version of IOS? I'm running 8.1.2. Anyway, other than this slight hiccup, I am actually very impressed with the app and look forward to learning more about the 34s (I've followed some of the discussions here on and off for the past few years, but never did take the leap to obtain one). Paul |
01-24-2015, 05:00 PM
RE: WP34s on iPhone
I've noticed a similar issue with the CONST menu when trying to select # at the bottom. It always takes me several trials until I succeed.
Cheers Thomas |
01-24-2015, 05:15 PM
RE: WP34s on iPhone
(01-24-2015 11:09 AM)pdo Wrote: This may be a dumb question but how do you get rid of the pull-down register/stack display in the WP34s iPhone app? No amount of poking or swiping seems to work :-( I agree that it is not that easy: the problem is that the App was designed before Apple bottom screen menu and that now, the screen area sensitive the gesture I defined is too small. I'll have a look at it in the incoming weeks. (01-24-2015 05:00 PM)Thomas Klemm Wrote: I've noticed a similar issue with the CONST menu when trying to select # at the bottom. It always takes me several trials until I succeed. Indeed. I'll have a look at it too as soon as I have some free time. Don't hold your breath. |
01-24-2015, 06:16 PM
RE: WP34s on iPhone | |||
01-24-2015, 09:34 PM
RE: WP34s on iPhone
(01-24-2015 11:09 AM)pdo Wrote: Hello All, "Pull" up right at "0" key - finger on white to avoid iPhone pull up menu |
01-25-2015, 01:33 PM
RE: WP34s on iPhone
(01-24-2015 09:34 PM)hewlpac Wrote: "Pull" up right at "0" key - finger on white to avoid iPhone pull up menu Yes, with some practice it becomes a little easier, but I think I'll avoid that display for now. I'm currently reading the excellent Beginner's Guide document, switching between it and the calculator on my iphone. Lots of fun! Paul |
02-17-2015, 08:23 PM
RE: WP34s on iPhone
A new version is available and should solve the aforementioned problems.
02-17-2015, 08:57 PM
RE: WP34s on iPhone
Many thanks for the fix: it works great!
Cheers Thomas |
02-18-2015, 03:31 PM
02-19-2015, 06:10 PM
02-19-2015, 06:51 PM
RE: WP34s on iPhone
(02-19-2015 06:10 PM)Jake Schwartz Wrote: Is there any chance we would see a version for Android? 1+ Please. --Bob Prosperi |
02-19-2015, 07:26 PM
RE: WP34s on iPhone
I have too much work at work to work on an Android version. The programming part is easy but supporting many screen resolutions is slightly complicated.
If someone wants to start the project, I can help but that's all. |
02-19-2015, 07:38 PM
RE: WP34s on iPhone
(02-19-2015 07:26 PM)pascal_meheut Wrote: I have too much work at work to work on an Android version. The programming part is easy but supporting many screen resolutions is slightly complicated. Thanks Pascal, I thoroughly get the too much work at work thing. That said, only 1 resolution is really important, at least to me; ther opinions may vary widely --Bob Prosperi |
02-20-2015, 05:35 PM
RE: WP34s on iPhone
I updated the wp34s app on my iPhone 6 running iOS 8.1.3 and when I try to call up certain functions the app closes and I'm back at the home screen.
This happens for me with
It doesn't happen with
02-20-2015, 07:01 PM
(This post was last modified: 02-20-2015 07:02 PM by pascal_meheut.)
RE: WP34s on iPhone
Indeed. It happens only on the iPhone, not the Apple emulator not the iPad Air 2 I'm using to develop it. Strange.
I'll look into it. |
02-20-2015, 07:24 PM
(This post was last modified: 02-20-2015 09:20 PM by pascal_meheut.)
RE: WP34s on iPhone
Ok. I found the bug and I have pushed a fix to the App Store. It can take several days before it is available though (9 days last time).
It was a compiler bug, a over-agressive optimization occuring only on some platforms. |
03-04-2015, 07:31 AM
RE: WP34s on iPhone
Another version is available. It fixes a few other bugs due to the new compiler.
I've also fixed the H.MS display: it used a @ instead of ° in font mode. The bug was also present in the Qt Emulators and of course, I fixed it too. |
03-04-2015, 11:23 AM
RE: WP34s on iPhone
Pascal,
Thank you for your work on this. I know it is not easy to keep a side project like this going. Your efforts are very much appreciated. |
