SpreadSheets - ONLY the first 999 Records show up Connectivity Pack!
02-06-2015, 07:07 AM
Just discovered ANOTHER BIG problem.
When you open a SpreadSheet in Connectivity Pack, ONLY the first 999 Records show up! 1,000-10,000 are nowhere to bee seen! In my program I am able to manipulate 1,000-10,000 fine. PS Please, Please HP fix the Connectivity Pack to make moving Spreadsheets, Lists and Matrices to/from a PC a simple task. |
10-08-2015, 03:34 PM
RE: SpreadSheets - ONLY the first 999 Records show up Connectivity Pack!
I wonder whether this might be another problem affected by the numerical display format.
It might be worth changing the display format to not use a thousands seperator (comma or dot) and then try again. Or has it already been fixed? Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
10-08-2015, 03:42 PM
(10-08-2015 03:34 PM)StephenG1CMZ Wrote: I wonder whether this might be another problem affected by the numerical display format. Its actually just a limit the authors of the original code had in there of which I was unaware... thanks. TW Although I work for HP, the views and opinions I post here are my own. |
