Visulisation of Vector - seperators
02-06-2015, 10:19 AM
hi all,
I wonder if it is possible to have seperators e.g.a colon or similar between the elements in a vectored result.
I've just discovered the spline() function, tried it and I am impressed. That will be useful in the future. A good practice for gaining some programming skills.
BUT I found it really hard to read the result. Seperators or wider spaces would be helpful. Can I activate something like that or is there any other recommended way to deals with huge results?
02-06-2015, 01:24 PM
RE: Visulisation of Vector - seperators
Perhaps mat2ist might help. Then use list2mat to convert back if needed
Graph 3D | QPI | SolveSys
02-08-2015, 01:53 AM
(02-06-2015 10:19 AM)Angus Wrote:  I wonder if it is possible to have seperators e.g.a colon or similar between the elements in a vectored result.
Turning off Textbook Display mode (page 2 in Home Settings) turns on commas between vector elements, which is nice, but it disables pretty math output, which is unfortunate. It's a tradeoff.
<0|ΙΈ|0>
-Joe-
