WP34s 20b Repurposed
02-22-2015, 06:28 PM
Post: #41
RE: WP34s 20b Repurposed
(02-22-2015 03:29 PM)John Galt Wrote:(02-22-2015 02:05 PM)Csaba Tizedes Wrote: If possible to make a 34s from a 20B or 30B, therefore is it possible to make a 30b from a 20b? (30b ROM upload to the 20b)?? Well protected IP I must say. You can load the image in an HP 20b but it will stay an HP 20b. The 30b functions are not available. I assume there is some hidden trick to identify the actual hardware and disable certain features depending on it. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
02-22-2015, 07:08 PM
Post: #42
IIRC, Tim Wessmann told us some months ago how the 20b and 30b differ. There is a little difference in the HW under the blob AFAIK.
d:-) |
02-23-2015, 11:04 PM
Post: #43
(02-22-2015 07:08 PM)walter b Wrote: IIRC, Tim Wessmann told us some months ago how the 20b and 30b differ. There is a little difference in the HW under the blob AFAIK.Yep, see here: http://www.hpmuseum.org/forum/thread-243...l#pid21873 It should be possible to identify the difference specifically probing for it in a debug firmware. Afterwards, it may or may not be possible to devise a hardware modification to eliminate this difference. Greetings, Matthias -- "Programs are poems for computers." |
