(50g) Quick Function Plotting Interface
02-21-2015, 02:39 PM
This program will allow you to plot one function using a simplified form instead of the 50g interface.
Code: << ‘X’ PURGE You can use RPN to build expressions. However, everything for the window variables must evaluate to numbers. For example, if you want to set xmax to 2π, use 2 π * →NUM [ENTER] |
