WP 34S: Estimated shelf life of Eric's overlays?
02-27-2015, 08:27 AM
Can anyone realistically assess the shelf life of the glue in unused overlays?
02-27-2015, 09:28 AM
RE: WP 34S: Estimated shelf life of Eric's overlays?
I've got one I use several times a week that is several years old now. Showing signs of wear but still good.
- Pauli
02-27-2015, 09:38 AM
(02-27-2015 09:28 AM)Paul Dale Wrote:  I've got one I use several times a week that is several years old now. Showing signs of wear but still good.
ditto
d:-)
02-27-2015, 09:55 AM
Here'a a picture of my WP 34S. It's several years old and is used about 1-2 times a month. It looks about the same as it did when I applied the labels.
02-27-2015, 10:32 AM
Thank you Paul, walter & Steve.
What about unused, fresh overlays? How long can they sit without the adhesive drying out?
02-27-2015, 10:48 AM
please move to "not quite ..." thread
02-27-2015, 11:09 AM
(02-27-2015 10:48 AM)Don Shepherd Wrote:  please move to "not quite ..." thread
Correct.
How?
02-27-2015, 12:17 PM
(02-27-2015 11:09 AM)Gerald H Wrote:  How?
Little Used part of Forum Software
TL;DR:
Use the [Image: postbit_report.gif] button.
02-27-2015, 12:56 PM
I had one overlay sit for about a year before using it. Some of the key tops had inadequate adhesive and required a spot of adhesive under them when placed on the calculator.
-- Sanjeev Visvanatha
02-27-2015, 02:42 PM
TL;DR:
thanks Thomas, I had thought that that button was used only to complain about a thread, but I see you can specify why you are "report"ing it.
Don
02-28-2015, 07:09 AM
(02-27-2015 08:27 AM)Gerald H Wrote:  Can anyone realistically assess the shelf life of the glue in unused overlays?
If they were hermetically sealed (or at least stored in a good plastic air-tight baggie with moisture and oxygen reducers, probably years. I think we may have had the same thought; purchase a few extra sheets from Eric now (in case they are rare later) knowing full well that the calculator is going to out-live the labels. I'm going one step further than that... I'm making 'several' units which I plan to store in a cool dry sealed environment hopeful that at least one of them will survive into old age with me (assuming of course that I survive into old age with me)
Smile
i am also working on moving forward with a design that will not require HP, nor Eric's labels.
Having said all of that... the enemy of the vinyl label is oil. The oil from your finger tips (hair) &c will weaken the gum. If you keep your hands clean and dry when using any fine instrument it will last longer. (don't smoke around your calculator; smoking destroys calculators and smoking destroys humans) Keep the calculator out of the sunlight, or any bright lighting frankly, and when possible keep it in a cool dry place (avoid dust, moisture and oils). I make sure my calcs have a zippered case where they are reliably and religiously stored when not in use. Hey, before I play my guitar, piano, flute or clarinet I was my hands and thoroughly dry them. I consider my calculator a fine instrument too (clean dry hands are essential, especially if you want your Eric stickers to last a long time).
And after all that... these vinyl labels are similar to the vinyl labels on a Rubic's cube (if you've played with one of those before, you know what I mean). I have a couple of those that are more than twenty-five years old... you guessed it, clean dry hands.
Cheers,
marcus
Smile
Kind regards,
marcus
02-28-2015, 10:19 AM
Smile
Cheers,
marcus
Smile
Very similar thinking in the first paragraph.
2nd para is beyond my capabilities.
Thanks for the tips.
I'm 62 this year & hope my stock of calculators will last till doomsday.
