Minehunt program
01-05-2014, 01:32 PM (This post was last modified: 01-06-2014 08:31 AM by LarsF.)
Minehunt program
From an idea from HP48G
// Version 0.1
// Lars Fredriksson
// 2013-2014
LOCAL rows,cols;
DRAW();
MOVE();
CHECK_BOMBS();
CHK();
EXPORT Minehunt()
  LOCAL Key,Pos:=1,Tmp,Bombs,Moves:=0;
  rows:=10;
  cols:=14;
  L0:=SORT(MAKELIST(RANDINT(rows*cols-3)+2,X,1,rows*cols*.2)); // make some bombs ca 20%
  L1:=MAKELIST(0,X,1,rows*cols); // make board
  L1(1):=1;
  RECT_P();
  Tmp:=Pos; //REMEMBER POS
  Bombs:=CHECK_BOMBS(Pos);
  DRAW(Pos,Bombs,0,"Bombs "+Bombs +" Moves "+Moves); // Draw board
  REPEAT
    FREEZE;
    Key:=WAIT();
    Pos:=MOVE(Key,Pos); // make a move
    L1(Pos):=1;
    //Have we moved
    IF Tmp≠Pos THEN
      Moves:=Moves+1;
      // Check if we step on a bomb
      IF POS(L0,Pos)≠0 THEN
        DRAW(Pos,Bombs,1,"Sorry, you step on a bomb after "+Moves+" moves"); // draw board and reveal bombs
        WAIT(−1);
        BREAK;
      // check if we get to the goal
      IF Pos==rows*cols THEN
        DRAW(Pos,Bombs,1,"Congratulations, you made it in "+Moves+" moves");
        WAIT(−1);
        BREAK;
      DRAW(Pos,Bombs,0,"Bombs "+Bombs +" Moves "+Moves); // redraw board
  UNTIL Key==4; //ESC
CHECK_BOMBS(P)
  LOCAL Count:=0;
  LOCAL LE:=0,RE:=0; // EDGE
  IF P MOD cols == 1 THEN
    LE:=1;
  IF P MOD cols == 0 THEN
    RE:=1;
  // count bombs in the neigbourhood
  IF LE==0 THEN
    Count:=Count+(POS(L0,CHK(P,P-cols-1))>0); //7
    Count:=Count+(POS(L0,CHK(P,P-1))>0);      //4
    Count:=Count+(POS(L0,CHK(P,P+cols-1))>0); //1
  Count:=Count+(POS(L0,CHK(P,P-cols))>0);   //8
  Count:=Count+(POS(L0,CHK(P,P+cols))>0);   //2
  IF RE==0 THEN
    Count:=Count+(POS(L0,CHK(P,P-cols+1))>0); //9
    Count:=Count+(POS(L0,CHK(P,P+1))>0);      //6
    Count:=Count+(POS(L0,CHK(P,P+cols+1))>0); //3
  RETURN Count;
CHK(T,A)
  IF A<1 THEN
    RETURN T;
  ELSE
    RETURN A;
DRAW(P,B,S,T)
 LOCAL X,Y,X1,X2,Y1,Y2,C:=1;
 // calculate size of boxes
 X0:=IP(320/(cols+2));
 Y0:=IP(240/(rows+2));
 X1:=IP(320/(cols+2));
 Y1:=IP(240/(rows+2));
 RECT_P(0,0,320,Y1,RGB(255,255,255),RGB(255,255,255));
 FOR Y:=1 TO rows DO
   FOR X:=1 TO cols DO
     IF L1(C)==1 THEN
       IF C==P THEN
         RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(128,255,128));
       ELSE
         RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(255,255,255));
     ELSE
       RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(180,180,180));
     IF S == 1 THEN  //SHOW BOMBS
       IF POS(L0,C)≠0 THEN
         IF C==P THEN
           RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(255,0,0));
         ELSE
           RECT_P(X*X0,Y*Y0,X*X0+X1,Y*Y0+Y1,RGB(0,0,0),RGB(255,180,180));
     C:=C+1;
 TEXTOUT_P(T,10,5);
 //BLIT_P(G1);
MOVE(KEY,P)
    LE:=1;
    RE:=1;
  CASE
    IF KEY==32 THEN  //7
      IF P-cols-1 >= 0 THEN
        IF LE==0 THEN
          P:=P-cols-1;
    IF KEY==33 THEN  //8
      IF P-cols >= 0 THEN
        P:=P-cols;
    IF KEY==34 THEN  // 9
      IF P-cols+1 >= 0 THEN
        IF RE==0 THEN
          P:=P-cols+1;
    IF KEY==37 THEN  //4
      IF P-1 >= 0 THEN
        IF LE==0 THEN
          P:=P-1;
    IF KEY==39 THEN  //6
      IF P+1 ≤ rows*cols THEN
        IF RE==0 THEN
          P:=P+1;
    IF KEY==42 THEN  //1
      IF P+cols-1 < rows*cols THEN
        IF LE==0 THEN
          P:=P+cols-1;
    IF KEY==43 THEN  //2
      IF P+cols ≤ rows*cols THEN
        P:=P+cols;
    IF KEY==44 THEN  //3
      IF P+cols+1 ≤ rows*cols THEN
        IF RE==0 THEN
          P:=P+cols+1;
    DEFAULT
  RETURN P;
01-05-2014, 04:07 PM
RE: Minehunt program
There is a syntax error in Line 108.
IF L1©==1 THEN What is the © for?
Can not figure out what the problem is,yet
01-05-2014, 04:13 PM (This post was last modified: 01-05-2014 04:14 PM by LarsF.)
Should be L( C )
01-05-2014, 09:53 PM (This post was last modified: 01-05-2014 09:59 PM by Terje Vallestad.)
(01-05-2014 04:13 PM)LarsF Wrote:  Should be L( C )
You are sure it should not be L1(C) rather than L(C)? I get a Syntax error with L(C) whilst L1(C) compiles fine....
Edit: I noted the forum software changes "L1( C )" to L1(C) Copyright which is unintended. Rewritten with a space either side of the C that should not be in the program.
Cheers, Terje
01-05-2014, 10:22 PM (This post was last modified: 01-05-2014 10:25 PM by LarsF.)
L1( C ) should it be, thanks. I should have use the code tag, note the quote tag, I believe i would look right then with spaces and no copyright signs...
01-05-2014, 11:24 PM
If you are interested I wrote a version.
HP PRIME PROGRAMS
[Image: minesweeper.jpg]
01-06-2014, 08:35 AM
I manage to change it to a code tag, looks much better now :-)
Tony, I already downloaded and played your nice little program, thanks.
