Unwanted Copyright symbol (C)
01-05-2014, 10:57 PM
Does anyone know how to avoid writing (C) Copyright symbol in the forum when you actually want ( C ) (but without the spaces either side of the C)?
I notice this recoding does not occur in the Subject line, why?
I could not find any reference to this on the MyBB website
Thanks, Terje
01-05-2014, 11:40 PM
RE: Unwanted Copyright symbol (C)
(01-05-2014 10:57 PM)Terje Vallestad Wrote:  Does anyone know how to avoid writing (C) Copyright symbol in the forum when you actually want ( C ) (but without the spaces either side of the C)?
This happens with (r) too. You'll see (r). This is a weird parsing issue in MyBB it even changes the way Latex expressions are shown. The only way I could find to get around this is to put in a formatting code and it's closure between the ( and the c.
So ( [ b ] [ / b ] c ) will work (take out all the spaces).
-katie
01-05-2014, 11:51 PM
Thanks Katie,
Will remember that for the future
Cheers, Terje
01-06-2014, 12:06 AM
Press button [B] to enter whatever.
And here we have some bold text.
Namir had the same problem with [ B ]. It was interpreted as bold tag.
Now we have a better workaround for this issue than having to use {B}.
Thanks
01-06-2014, 12:29 AM
(TM) too: (TM)
Greetings,
    Massimo
01-06-2014, 03:38 AM
I should be able to remove the C, R, TM automagic in a few days.
01-08-2014, 06:01 AM (This post was last modified: 01-08-2014 06:17 AM by Dave Hicks.)
I've removed the automagic for (c) (r) and (tm).
01-08-2014, 07:41 AM
Yes you have! I don't see them anymore in the old posts.
Thank you.
Greetings,
    Massimo
01-08-2014, 07:58 AM
(01-08-2014 06:01 AM)Dave Hicks Wrote:  I've removed the automagic for (c) (r) and (tm).
Thank you Dave,
Cheers, Terje
