Dynamic local variables
03-13-2015, 07:59 PM
Here's an example of how to create dynamic local variables:
Code: locvars:={}; Explanation to come a bit later; heading home from work. Graph 3D | QPI | SolveSys |
03-14-2015, 10:56 AM
RE: Dynamic local variables
thanks Han,
another bookmark for my "study soon the Prime programming" folder ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
03-15-2015, 07:44 PM
(03-13-2015 07:59 PM)Han Wrote: Here's an example of how to create dynamic local variables: And for the explanation: Normally, one must declare all variables prior to their use. In this template, one only has to declare two generic container variables: localvars and localname. The variable localvars stores the values of the variables whereas localname stores their ascii names. We use localname as a lookup table to determine the index to use within localvars get the corresponding value. NEWLOC("varname", type) -- creates a variable with name "varname" and initializes it to either 0 or {0} depending on whether type is 0 or non-zero (atomic versus composite variable). Thus, to create a list, one could do: NEWLOC("mylist",1). If that variable already exists, then it is reset. If not, then it is created as a new entry in both localvars and localname. LSTO("varname",value) -- stores a value into "varname" LSTON("varname", value, index) -- stores a value into the n-th position in a composite variable "varname". For example, LSTON("mylist",-3,5) is equivalent to mylist(5):=-3 LRCL and LRCLN behave similarly but recalls the value stored in the local variables. Graph 3D | QPI | SolveSys |
05-19-2019, 08:35 PM
(03-13-2015 07:59 PM)Han Wrote: Here's an example of how to create dynamic local variables: (03-15-2015 07:44 PM)Han Wrote:(03-13-2015 07:59 PM)Han Wrote: Here's an example of how to create dynamic local variables: //// this does not run on HPG2 why. |
05-20-2019, 04:52 AM
(05-19-2019 08:35 PM)tom234 Wrote:(03-13-2015 07:59 PM)Han Wrote: Here's an example of how to create dynamic local variables: What issues did you run into? Were there any error messages at all? Graph 3D | QPI | SolveSys |
