(38G)Modulo Powering
03-15-2015, 08:22 AM
(This post was last modified: 06-15-2017 01:57 PM by Gene.)
The programme POWMOD takes a list of 3 integers from the HOME stack,
eg { 2 , 540 , 541} & returns 2 ^ 540 MOD 541 in Ans & variable X. Answers are correct for positive integer values of the 3 integers < 10^12. POWMOD Ans►L0: L0(1)►A: L0(2)►N: L0(3)►M: RUN PMOD: The programme PMOD uses the values in A, N & M to calculate A ^ N MOD M. PMOD 1►X: WHILE N REPEAT IF N MOD 2 THEN A►H: RUN MMOD: N-1►N: END: A►F: RUN SMOD: Ans►A: N/2►N: END: X: The programme MMOD finds X * H MOD M. MMOD X MOD 1000000►I: X-Ans►X: H MOD 1000000►J: H-Ans: ((X*Ans MOD M+((X*J MOD M+I*Ans MOD -M) MOD -M))MOD -M+I*J )MOD M►X: The programme SMOD finds Ans ^2 MOD M. SMOD Ans►F: F MOD 1000000►I: F-Ans: (((((Ans^2 MOD -M+Ans*I MOD M) MOD -M)+Ans*I MOD M)MOD -M)+I^2)MOD M: If you're interested in number theory on the 38G try this: http://www.hpcalc.org/hp38/math/numtheory38.zip If you replace MMOD & SMOD with the newer versions here all programmes are valid up to 10^12 - 1. |
