Spreadsheet - Renaming Columns - Errormessage
03-19-2015, 05:27 PM
After renaming a column in the spreadsheet, e.g. the first column from ‘A’ to ‘Alpha’, it seems impossible to change the name back to ‘A’. There is only a message “Error: Invalid input”. Is there a simple workaround?
03-19-2015, 05:39 PM
RE: Spreadsheet - Renaming Columns - Errormessage
(03-19-2015 05:27 PM)Dirk. Wrote: After renaming a column in the spreadsheet, e.g. the first column from ‘A’ to ‘Alpha’, it seems impossible to change the name back to ‘A’. There is only a message “Error: Invalid input”. Is there a simple workaround? Select the cell and press DEL My website: ried.cl |
03-19-2015, 05:44 PM
Thank you very much!
Not intutive to me, but very simple and working. And it does not delete the contents of the whole column. |
