Get Statistics results in a program...
03-23-2015, 02:05 PM
hi,
why I get error with this code? Code:
if I type "Statistic_2var.MeanY" in CAS or Home it's ok, but I get error in a program... where I'm wrong? thank you in advance, Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
03-23-2015, 04:47 PM
RE: Get Statistics results in a program...
Mine reboots if I eval Statistic_2var.MeanY in home
My website: erwin.ried.cl |
10-09-2015, 07:44 AM
(This post was last modified: 10-09-2015 08:02 AM by StephenG1CMZ.)
This is probably obvious, but what I have found so far on the Android emulator:
The App is statistics with an s: Statistics_2Var If you select the variables from the toolbox/App/Statistics_2Var, Resid is listed but MeanY is not. Suggesting that perhaps that variable is not defined in that App. I also tried1Var: same . But typing it in at Home gives Error: Insufficient data (I haven't set any up), meaning Home recognises MeanY. Update: But then I re-edited my program changing 1Var.MeanY back to 2Var.MeanY - and now it compiles! So: Did I have a typo earlier? Or did the Home evaluation change something? Code:
Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
11-12-2015, 01:41 AM
You may have ran into the same problem I ran into. It depends on the mode type used. In any case you can review what I posted as a possible work around. Please review the following thread.
http://www.hpmuseum.org/forum/thread-5111.html Michael |
