programming the prime
03-24-2015, 08:57 PM
Hello to the forums!
I am relatively new to the prime and somehow stuck in the learning process. As a result it is likely that I will post several dumb or silly questions in the future.
I hope you can help me with the machine....
Based on some tutorials I tried the following
EXPORT fircore(N)
  LOCAL core:=seq(0,N);
Codecheck complains: Syntax Error.
EXPORT fircore(N)
  LOCAL core:=seq(0,10);
That would work.... Can you explain the issue and give startup tips to master the machine some day?
Thanks
03-24-2015, 09:15 PM (This post was last modified: 03-25-2015 06:25 AM by Han.)
RE: programming the prime
(03-24-2015 08:57 PM)leprechaun Wrote:  Hello to the forums!
EXPORT fircore(N)
EXPORT fircore(N)
Thanks
You're using the "," for fractional separators. This in turn makes the separator character ";" (by default, the "." is the fraction mark and "," is the separator). Thus, when you type:
seq(0,10)
it gets interpreted as call the seq() function with a single argument whose value is \( \frac{1}{10}\). It doesn't work in the case of seq(1,N) because the calculator does not allow symbolic fractional parts. Press [Menu] while program editor and select "Insert Pragma" (place it at the top) and change the ( , ; ; ) to ( . , ; ) if you want to use regular commas and decimal points in your programs but not elsewhere. The alternative is to make sure that you remember "," means fraction mark, and ";" means separator. [Edit] Or thirdly, change your numeric display option in the settings.
The pragma ( . , ; ) tells the editor that "." is the fraction mark, "," is the separator, and ";" ends a command line. So you could theoretically use: ( , . ; ) if you want, or even ( , ; , ) and end all commands with a "," symbol! (Not all symbols are allowed, though.
Graph 3D | QPI | SolveSys
03-25-2015, 12:04 PM
All sollutions work! Thank you.
I would have NEVER figured that out. I think a pragma is the best just in case I'll share my programs with somebody in the future. You never know.
I am sure there are dozens of similar trivial problems to come ;-)
