How to arrange labels within the INPUT command?
03-26-2015, 07:35 PM
(This post was last modified: 03-27-2015 05:25 AM by Spybot.)
Hi Everyone! I'm trying to display some labels within the INPUT command... everything is fine, except for the fact that I need those labels to show on the right side of the box(just like in the LINEAR SOLVER APP) , I know the default is to show them on the left side of the box. So, Is there a way to show them to the right? Thank you. Spybot. |
03-26-2015, 07:52 PM
(This post was last modified: 03-26-2015 07:53 PM by toml_12953.)
RE: How to arrange labels within the INPUT command?
(03-26-2015 07:35 PM)Spybot Wrote: Does adding leading spaces work? Tom L Cui bono? |
03-26-2015, 11:07 PM
(This post was last modified: 03-27-2015 05:26 AM by Spybot.)
This is my code:
EXPORT TEST() BEGIN LOCAL A; INPUT({{A,[0],{50,10,2}}},"title","Label"); //NO help! END; the result is shown in screenshot #1 but I'd like to achieve something like the screenshot # 2 without PhotoShop. Spybot. |
03-27-2015, 11:38 AM
(This post was last modified: 03-27-2015 11:43 AM by DrD.)
Arranging labels independently may not be a built in feature of the INPUT command, but in a desparate act of dogged determination you could embellish this skeleton idea to possibly achieve what you are after, (this is just a 'food for thought' notion, not a fully working example):
03-27-2015, 03:20 PM
(This post was last modified: 03-27-2015 03:49 PM by Spybot.)
Hi Thank you for your answer DrD!
I admit that it is a very clever and informative approach, it definitely shows more that I expected, now I got a clear notion not only on how the INPUT command really works at this moment, but also how other commands work. I appreciate you took the time to generate this answer. Spybot. Spybot. |
10-06-2017, 09:51 AM
Bonjour,
I am looking to find a way to input some data in my defined screen with rect_p() and textout_p. I tried the code above, but it does not work as I want and require wait(0) ! Is it a way to accomplish easily this with INPUT. note : INPUT command bypass my defined screen with standard screen !... Thanks a lot for your attention. DL |
